Yk locker okd question with twist - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yk locker okd question with twist
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-09-2016, 01:58 PM   #1
billybooster2
1983 CJ8
Daughter's yj now has ome 36r springs and 31's She enjoys mild wheeling and 'should' get new gearing however I feel an aussie would suit her well. The only axle mod I've done on hers is to permanently link the left snd right front axle by engaging the pin therein. Front driveshaft is balanced and is always spinning. Axles are 35/30 stock in a pretty much unwheeled vehicle. My question; if i put ONE locker only in, front or rear? Not the place for explaining that a d35 isn't worth the investment.. Just wanna know whether to do front or back
billybooster2 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2016, 02:13 PM   #2
gotswap
Without going in to too much drama, it is better to invest in the front axle than the rear axle. With that, you may not like an auto locker in the front axle if you have locked the collar over.
my 2 cents
gotswap is offline   Reply With Quote Quick reply to this message
Unread 01-09-2016, 02:27 PM   #3
billybooster2
1983 CJ8
Originally Posted by gotswap
Without going in to too much drama, it is better to invest in the front axle than the rear axle. With that, you may not like an auto locker in the front axle if you have locked the collar over. my 2 cents
yes, collar is locked-but doesnt that make it essentially a TJ?.
Unread 01-09-2016, 04:35 PM   #4
93YJfalcon
I have TJ shafts and an Aussie locker front and rear. They're basically invisible as long as your front drive shaft is balanced.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline   Reply With Quote Quick reply to this message
Unread 01-09-2016, 05:31 PM   #5
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
http://www.jeepforum.com/forum/f12/l...-rear-1364905/
http://www.jeepforum.com/forum/f12/f...-first-664870/
http://www.jeepforum.com/forum/f12/a...t-rear-636350/
http://www.jeepforum.com/forum/f12/a...t-rear-526039/
http://www.jeepforum.com/forum/f12/l...t-rear-312847/
http://www.jeepforum.com/forum/f12/a...t-rear-250038/
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 01-09-2016, 05:33 PM   #6
Reno72
Reno72's Avatar
I much prefer the rear locked first, but with your restrictions I'd do the front.
92 Rene, 4.5 RE lift, Currie ARB D44, super 8.8 ARB
YJOTM. 12/15
Reno72 is online now   Reply With Quote Quick reply to this message
Unread 01-09-2016, 06:42 PM   #7
Louie4
What Joe said.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is online now   Reply With Quote Quick reply to this message
Unread 01-09-2016, 06:53 PM   #8
billybooster2
1983 CJ8
So Front then.
Thanks every one
Unread 01-09-2016, 06:55 PM   #9
timatoe
I would and did do the front first. Especially where you're located, not like you've got a lot of snow or anything to contend with.
timatoe is offline   Reply With Quote Quick reply to this message
