YJ and ZJ trans case swaps - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ and ZJ trans case swaps
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-17-2014, 06:49 PM   #1
cruisingram
I have a 94 YJ wrangler and a 93 ZJ grand cherokee parts vehicle. Both have NP 231s. My YJ needs a trans case swap and I would like to swap in the ZJ part if possible? Anyone help me out on this?
cruisingram is offline   Reply With Quote
Unread 04-17-2014, 07:02 PM   #2
rambo3489
rambo3489's Avatar
Ittl bolt right up. The only thing that might change is the number of splines on the t case input shaft. Also are they both slip yokes or both have SYEs? The t case will bolt right up and be golden unless the spline count is different. If it's different that means a total disassemble of the tcases and basically swap of internals. (Except the bad parts. They stay)
Do a little research on the YJ year and the ZJ year with relation to the t case spline count. I think there the same.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
BUILDING THE YJ MY WAY
rambo3489 is offline   Reply With Quote
Unread 04-17-2014, 07:08 PM   #3
rambo3489
rambo3489's Avatar
I forgot the Cherokee s come with different length input shafts. So that might be a problem too. But looks like ZJs didn't come stock with the 231. So it might be from a wrangler of some type. In which case you'll be good. Other wise pull the cases apart and swap the input shafts. Its not too bad. Basically a SYE install.
Unread 04-17-2014, 07:14 PM   #4
MurdaJs
Input shaft length doesn't matter for a nv3500, not sure about the AX. In auto trans the length is important because it seals the trans, it diesnt seal anything in my 5 speed
In 93-94, a 4.0 ZJ could have come with a 231. Every ZJ tcase has 23 spline input shaft.
Built one piece at a time, and it cost me many dimes
MurdaJs is offline   Reply With Quote
Unread 04-17-2014, 08:11 PM   #5
cruisingram
The 93 is definately a 231
Unread 04-17-2014, 08:21 PM   #6
MurdaJs
Gotcha, just saying "could have" because it isn't the most common thing in a ZJ
But it is 23 spline, and yours iirc is 21 spline since you have a 4 banger. You can probably swap input shafts. I say "probably" because I don't know too much about yjs, maybe someone that does will chime in.
Here's a link to t case info about ZJs, and input shaft swap writeup
http://www.jeepforum.com/forum/f13/t...-np242-685644/
Unread 04-18-2014, 01:09 AM   #7
cruisingram
I have another ZJ going to tow home this week. It is also a 231. Wierd- is it a Hawaii thing? And the sucky thing is- in 94- looks like it is totally impossible to tell if it is a 21 or 23 spline in 94 Wranglers- they used both at random if I am reading correctly.
Unread 04-18-2014, 02:47 AM   #8
SeanB95YJ
SeanB95YJ's Avatar
it shouldn't be random.... YJs with the 2.5/ax5 should be 21 spline, and the 4.0/ax15 YJs should be 23 spline
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread: http://www.jeepforum.com/forum/f22/a...hread-1542284/
SeanB95YJ is offline   Reply With Quote
Unread 04-18-2014, 03:09 AM   #9
cruisingram
Ok- that is good to know- thanks. I just read somewhere that in 94 Yjs had some kind of mid-year transfer case issue as far as what they used in them. Did I read this wrong? Or was it the diff between the 6cyl and 4cyl spline count they were talking about?
Unread 04-18-2014, 06:30 AM   #10
MurdaJs
There is a gear cut change mid 94, means you can't swap input shafts between 93 and 95 t cases.
But if, like the nv3500, the ax5 isn't sealed by the tcase input shaft, then length shouldn't matter. It's the spline count you'll have to worry about. Your 93 ZJ tcase is definitely swappable, your 94 is a maybe
