Yj won't STOP running - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj won't STOP running
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 06-13-2012, 11:57 AM   #1
mikesavage71
Replaced the carb with weber and got rid of the majority of emissions clutter. Did the nutter bypass and finally removed extra wires not being used. Now when I turn off the key, the engine runs for 10-15 seconds with the key completely out, then sputters and dies? I think I cut the wrong wire but can't find any help with chitons or Haynes books.
1989 yj with 4.2
mikesavage71 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 01:06 PM   #2
erushing
1987 YJ Wrangler
Did you check the timing
erushing is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 01:07 PM   #3
Que89YJ
No you didn't cut the wrong wire. The alternator is backfeeding the coil. You need to add a diode to clamp the voltage.
http://www.jeepforum.com/forum/f12/d...rnator-873928/
http://www.jeepforum.com/forum/f12/9...49/index2.html
Que89YJ is online now   Reply With Quote Quick reply to this message
Unread 06-13-2012, 01:22 PM   #4
giggityjeeper
count your lucky stars......
most cant get them running........
Started with some rust repairs ended in a SOA...
http://www.jeepforum.com/forum/f12/h...-jeep-1050879/
family roll bar swap/upgrade..
http://www.jeepforum.com/forum/f12/f...grade-1054753/
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 03:06 PM   #5
Que89YJ
Lol that is funny!
Unread 06-13-2012, 03:17 PM   #6
MegaCabMan
mine does the same thing if I don't turn the headlights off befor shutting the engine off. as was said earlyer,it just needs a diode.
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
MegaCabMan is offline   Reply With Quote Quick reply to this message
Unread 08-29-2012, 02:28 PM   #7
mikesavage71
Would not having the diode result in this weeks completely corroding the ignition coil end of the distributor wire to the point it just fell out? every other end is good, timing is good, plug gap is good, no other corrosion at all.
Unread 08-29-2012, 08:03 PM   #8
Que89YJ
It shouldnt have Mike. Just bad luck on an old electrical system.
engine , wiring , YJ
