yj wont start off key? - JeepForum.com
post #1 of 4 Old 07-27-2012, 07:40 AM Thread Starter
natefilms
It cranks over,it has a weak yellow spark,getting 10 volts to the coil,itll drift start,its got a good starter,coil,rotor button wires,alternator,and battery....any ideas?
natefilms is offline
post #2 of 4 Old 07-27-2012, 09:18 AM
Que89YJ
You need to fill out the profile. The YJ had some major changes through the years and the mods are important as well if you know there are major changes.
Que89YJ is offline
post #3 of 4 Old 07-27-2012, 11:57 AM Thread Starter
natefilms
It's a 2.5liter 4cly 5spd the wiring harness isnt a 91 model's idk wat year the motor is for shore,the rotor button distributor and coil are not original ether ...
post #4 of 4 Old 07-27-2012, 12:01 PM
Que89YJ
Start with this and post back the fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
key , start , wrangler , YJ
Help Jeep wont start turns over but wont start 1990blackyj YJ Wrangler Technical Forum 17 01-13-2012 03:33 PM
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 05:37 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 04:13 PM
