Yj won't start after engine rebuild - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj won't start after engine rebuild
Cold Air Intake and Throttle Body Spacer KitKrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-01-2013, 11:01 AM   #1
TFERGUSON2005
I rebuilt my 2.5 liter and now I can't get it to start. It would run before rebuild but had lots of blow by due to a hole in number for piston. This is the first jeep rebuild I done so I took lots of pics to ensure the assembly. Any recommendations?
TFERGUSON2005 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 01:07 PM   #2
EABiker
Start with the basics. Make sure you have fuel getting to the engine. You can pour a small amount into the intake and see if it tries to start. If so, you have spark, and no fuel. Verify voltage to the coil, check CPS connection, as well as the other sensors.
EABiker is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 02:49 PM   #3
VenomousMaximus
Timing?
VenomousMaximus is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 09:12 PM   #4
TFERGUSON2005
I think the timing is off some how I set it just as the book said but I rotated the plug wires on the cap counter clockwise a quarter turn and got it to fire and run but was holding throttle half open and it ran really rough. I guess I will take down and start overon the timing. Any little tricks to ensuring timing is done right?
