Yj won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj won't start
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-19-2014, 05:39 PM   #1
dhoepp
Yj won't start
5 speed YJ won't start. No clicks. Pop started and drove just fine for about 5 minutes and still doesn't start. All the lights and everything work, when I turn the key, the brake light comes on in the dash.
dhoepp is offline   Reply With Quote Quick reply to this message
Unread 10-19-2014, 05:40 PM   #2
dhoepp
Thanks for any and all help.
Unread 10-19-2014, 05:49 PM   #3
Ncdeere
If it is not turning over try rapping on the starter with a hammer to free up the brushes. Not hard, just a good tap to vibrate the brushes. Mine just did the same thing. The brushes may need replacing.
Ncdeere is offline   Reply With Quote Quick reply to this message
Unread 10-19-2014, 06:00 PM   #4
dhoepp
I've been driving it all day. The 5th time I go to start it just nothing.
Unread 10-19-2014, 06:58 PM   #5
mike134
Definitely try hitting the starter with a hammer. Be firm with your hit, not too gentle.
Also, when you first turn the key to ON, does the check engine light come on? If not, you may need to replace the capacitors in your computer.
Could you clear up some ambiguity with your description? You bump started the vehicle, then you ran it for 5 minutes and turned it off, or did you run it for 5 minutes and then it died?
mike134 is online now   Reply With Quote Quick reply to this message
Unread 10-19-2014, 07:04 PM   #6
dhoepp
I turned it off. I've got it running right now to hopefully charge the battery.
Unread 10-19-2014, 07:11 PM   #7
dhoepp
While its running I can turn the key for a second and get that grinding sound. So it's not the starter. And I get the check engine light when turning the key to power. Let it charge for 20 minutes and I still get nothing.
Unread 10-19-2014, 07:17 PM   #8
TSEJEEPERS
TSEJEEPERS's Avatar
Pull out your your battery and alternator and have them tested.
If your battery is over 3 years old replace it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 10-19-2014, 07:52 PM   #9
mike134
I agree with testing the battery and alternator then.
Sounds like you don't have enough power on start-up. Hopefully the alternator is fine since the engine runs ok with the bump start (may still be bad though). First, you can just pull the battery out and take it to autozone. Have them charge it and test if for free.
Unread 10-20-2014, 12:19 AM   #10
dancytron
Bad battery cables and/or bad connections. . . They can look good and still be bad.
dancytron is offline   Reply With Quote Quick reply to this message
Unread 10-25-2014, 12:20 PM   #11
dhoepp
Gave the starter a few taps. That got it.
