Yj wont crank, plz help! - JeepForum.com
post #1 of 2 Old 07-24-2013, 11:05 AM Thread Starter
masterjqx
i have a 91 yj. i parked it the other day, went out a couple days later and no crank. no turn over nothing. battery is good, all lights work turn signals ect. with the ignition on i jump the starter and it only spins does not engage, if i try to pull start it, it only putters its not geting fuel or spark? anyone have any ideas? thanks!
Ride it till it breaks!
masterjqx is offline
post #2 of 2 Old 07-24-2013, 11:38 AM
youngjeepr
So it won't crank with the key but if you bypass the solenoid it does? If that's the case your starter solenoid is bad.
By pull start I assume you mean get the vehicle rolling and popping the clutch? When you do that it still won't run?
Have you checked for spark or fuel?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
