Yj won't STOP running - JeepForum.com
post #1 of 8 Old 06-13-2012, 10:57 AM Thread Starter
mikesavage71
Replaced the carb with weber and got rid of the majority of emissions clutter. Did the nutter bypass and finally removed extra wires not being used. Now when I turn off the key, the engine runs for 10-15 seconds with the key completely out, then sputters and dies? I think I cut the wrong wire but can't find any help with chitons or Haynes books.
1989 yj with 4.2
mikesavage71 is offline
post #2 of 8 Old 06-13-2012, 12:06 PM
erushing
1987 YJ Wrangler
Did you check the timing
erushing is offline
post #3 of 8 Old 06-13-2012, 12:07 PM
Que89YJ
No you didn't cut the wrong wire. The alternator is backfeeding the coil. You need to add a diode to clamp the voltage.
http://www.jeepforum.com/forum/f12/d...rnator-873928/
http://www.jeepforum.com/forum/f12/9...49/index2.html
Que89YJ is offline
post #4 of 8 Old 06-13-2012, 12:22 PM
giggityjeeper
count your lucky stars......
most cant get them running........
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #5 of 8 Old 06-13-2012, 02:06 PM
Que89YJ
Lol that is funny!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 8 Old 06-13-2012, 02:17 PM
MegaCabMan
mine does the same thing if I don't turn the headlights off befor shutting the engine off. as was said earlyer,it just needs a diode.
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
MegaCabMan is offline
post #7 of 8 Old 08-29-2012, 01:28 PM Thread Starter
mikesavage71
Would not having the diode result in this weeks completely corroding the ignition coil end of the distributor wire to the point it just fell out? every other end is good, timing is good, plug gap is good, no other corrosion at all.
post #8 of 8 Old 08-29-2012, 07:03 PM
Que89YJ
It shouldnt have Mike. Just bad luck on an old electrical system.
Fault codes:
No Start:
Que89YJ is offline
engine , wiring , YJ
04 Rubicon Stop Running KneeDeepinMudd TJ Wrangler Technical Forum 5 01-30-2011 09:48 AM
4.0 runs good but wont stay running at stop lights. Isaiah17 YJ Wrangler Technical Forum 16 10-19-2008 09:45 PM
jeep running kinda choppy when in gear at a stop sign drews0311 YJ Wrangler Technical Forum 7 05-24-2007 04:46 AM
It finally runs, but won't stop running kbazurpe YJ Wrangler Technical Forum 3 08-10-2006 03:36 PM
Running 31's on stock-No bump stop Adjustment hikerpaddler TJ Wrangler Technical Forum 13 05-02-2005 05:12 PM
