Yj won't start - JeepForum.com
post #1 of 11 Old 10-19-2014, 04:39 PM Thread Starter
dhoepp
Yj won't start
5 speed YJ won't start. No clicks. Pop started and drove just fine for about 5 minutes and still doesn't start. All the lights and everything work, when I turn the key, the brake light comes on in the dash.
dhoepp is offline
post #2 of 11 Old 10-19-2014, 04:40 PM Thread Starter
dhoepp
Thanks for any and all help.
dhoepp is offline
post #3 of 11 Old 10-19-2014, 04:49 PM
Ncdeere
If it is not turning over try rapping on the starter with a hammer to free up the brushes. Not hard, just a good tap to vibrate the brushes. Mine just did the same thing. The brushes may need replacing.
Ncdeere is offline
post #4 of 11 Old 10-19-2014, 05:00 PM Thread Starter
dhoepp
I've been driving it all day. The 5th time I go to start it just nothing.
dhoepp is offline
post #5 of 11 Old 10-19-2014, 05:58 PM
mike134
Definitely try hitting the starter with a hammer. Be firm with your hit, not too gentle.
Also, when you first turn the key to ON, does the check engine light come on? If not, you may need to replace the capacitors in your computer.
Could you clear up some ambiguity with your description? You bump started the vehicle, then you ran it for 5 minutes and turned it off, or did you run it for 5 minutes and then it died?
mike134 is offline
post #6 of 11 Old 10-19-2014, 06:04 PM Thread Starter
dhoepp
I turned it off. I've got it running right now to hopefully charge the battery.
dhoepp is offline
post #7 of 11 Old 10-19-2014, 06:11 PM Thread Starter
dhoepp
While its running I can turn the key for a second and get that grinding sound. So it's not the starter. And I get the check engine light when turning the key to power. Let it charge for 20 minutes and I still get nothing.
dhoepp is offline
post #8 of 11 Old 10-19-2014, 06:17 PM
TSEJEEPERS
Pull out your your battery and alternator and have them tested.
If your battery is over 3 years old replace it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 11 Old 10-19-2014, 06:52 PM
mike134
I agree with testing the battery and alternator then.
Sounds like you don't have enough power on start-up. Hopefully the alternator is fine since the engine runs ok with the bump start (may still be bad though). First, you can just pull the battery out and take it to autozone. Have them charge it and test if for free.
mike134 is offline
post #10 of 11 Old 10-19-2014, 11:19 PM
dancytron
Bad battery cables and/or bad connections. . . They can look good and still be bad.
dancytron is offline
post #11 of 11 Old 10-25-2014, 11:20 AM Thread Starter
dhoepp
Gave the starter a few taps. That got it.
dhoepp is offline
