yj wiring harness thinning - JeepForum.com
post #1 of 6 Old 02-20-2012, 08:05 PM Thread Starter
liftedyj91
im swapping in a sbc 350. my question is i need to thin the harness out. now can i just cut the old pcm harness off and be done with it, or is there more to it that??
check out
to see my build!
liftedyj91 is offline
post #2 of 6 Old 02-21-2012, 06:27 AM Thread Starter
liftedyj91
bump! cmon people. i need some help!
check out
to see my build!
post #3 of 6 Old 02-21-2012, 06:33 AM
coneal30
i hope someone answers this, but i have not received many answers to electrical questions either.
coneal30 is offline
post #4 of 6 Old 02-21-2012, 07:00 AM
dillonjm
2013 WK
You can cut out any wiring that isn't used by the engine/gauges/fuel or charging systems.
Ie is you're not using the factory computer for anything there is no need to keep it in the jeep.
You can keep things easier by repurposing some of the wiring and sensors if you're trying to integrate your factory gauges.
Its really all up to you what your keep and remove. There is no magic answer.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 6 Old 02-21-2012, 10:31 AM
94YJCRAIG
Are you keeping the stock gauge's? Is the sbc fuel injected?
94YJCRAIG is offline
post #6 of 6 Old 02-21-2012, 10:43 AM
jbolty
jbolty's Avatar
Obviously the old computer is not going to be of any use with a new engine. If you want a clean harness trace each wire from the ECM connector and remove it, along with whatever is connected on the other end. Or, find the wires you want to keep for the gauge senders, lights, the starting and charging circuits and cut out everything else.
Sort of like this.
And don't be so impatient. 7pm til 5am is not exactly prime time.
jbolty is offline
Wiring Harness ColoradoCole TJ Wrangler Technical Forum 1 01-20-2012 04:55 PM
Wiring harness MrRage TJ Wrangler Technical Forum 0 08-06-2010 03:58 PM
wiring harness jerseyrider1119 YJ Wrangler Technical Forum 7 11-02-2009 10:20 PM
Wiring Harness for JK corey3589 JK Wrangler Technical Forum 19 02-04-2007 09:17 AM
yj wiring harness? jiffi YJ Wrangler Technical Forum 1 03-31-2005 06:07 PM
