YJ Wiper problem - JeepForum.com
post #1 of 12 Old 01-19-2011, 06:30 PM Thread Starter
YJXRCJeep
YJ Wiper problem
I have a 93 YJ. I've already replaced the Relay and re-wired the Motor to the switch at the connector but they still work intermittently. The switch is good because I've already checked the connectors with a multimeter. The only two things I haven't touched are the intermittent wiper relay box and the ground wire. After not having wipers for a month I drove it to school today and they started working after I drove the brick roads. Any suggestions?
YJXRCJeep is offline
post #2 of 12 Old 01-19-2011, 06:39 PM
carlitos_90
1st check your ground wire. ..
2nd step. have ur jeep on the ON position. (dont start it) ... turn ur wipers on. and go shake the wiper relay box... if they come on. at anytime during that time you shake it. you prob have short in the box or around it. . (shake the cables going to it as well)
hope that helps bit
carlitos_90 is offline
post #3 of 12 Old 01-19-2011, 06:40 PM
letitloose06
Remove the intermittent wiper module and plug the two connectors together and see if your wipers work on fast, slow and mist settings. If they do, you need a new module. If you can live without the intermittent wipers, then just leave it without the module.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 BFG KM2's, 8.8 Rear, HP30 front, 4.10's, SYE and CV Driveshaft, Taurus Electric Fan, 136 A GC Alternator, Grand Prix Seats, RR HD Steering, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
letitloose06 is offline
post #4 of 12 Old 01-19-2011, 06:41 PM
carlitos_90
x2
post #5 of 12 Old 01-19-2011, 06:56 PM Thread Starter
YJXRCJeep
Sounds like a plan, I'll grab a flashlight and go check that stuff in a few. Is the ground wire on the bottom of that intermittent wiper plate? Thanks
post #6 of 12 Old 01-19-2011, 07:13 PM
carlitos_90
dont know... ignore that ground..(for now). till i find out (need look at some diagrams. sometime tomorrow ... but go ahead and check the rest of the stuff. mentioned
post #7 of 12 Old 01-19-2011, 07:19 PM
carlitos_90
i can tell u were the intermittent module should be located. (under instrument panel next to the steering column)
and that their controls washer pump as well and everything else high/ low settings.. btw does that work? washer pump? (even turns on?)
post #8 of 12 Old 01-19-2011, 07:27 PM
carlitos_90
post #9 of 12 Old 01-19-2011, 07:53 PM Thread Starter
YJXRCJeep
Yeah the washer pump turns on but when I take the intermittent box out of the equation the wipers don't come on when the pump does. I just need to know where that ground wire is so I can take that out of the equation. Everything else checks out but the ground and the intermittent box. When I flip the wipers on with the IB (Intermittent box) plugged in there is a clicking like a relay makes several times and then a delay and then they start working. I will Bypass the IB and drive around the brick roads and run the wipers and see if they stop at all.
post #10 of 12 Old 01-24-2011, 09:08 AM
Ksyrium
1987 YJ Wrangler
I just put a new connector on my ground yesterday - my electrical power was low & got better w/ higher RPM's. All good - so far.
My ground (that I reworked) was on the motor block - passenger side, below the valve cover maybe 4" from the very back of the motor. (so b/w the coil & the firewall). Hope that helps.
ΜΟΛΩΝ ΛΑΒΕ
Ksyrium is offline
post #11 of 12 Old 02-06-2011, 11:37 PM
carlitos_90
bump.. did you find anything?
post #12 of 12 Old 02-07-2011, 12:19 PM Thread Starter
YJXRCJeep
Yeah. It was the ground. When I replaced my exhaust manifold, cleaned my intake and replaced my valve cover gasket I had all the wires undone. The ground wire wasn't making contact so when I plugged everything back in, properly, it fixed the problem.
wiper problem? kingofkings YJ Wrangler Technical Forum 1 06-01-2010 10:59 PM
wiper problem maddogusmc JK Wrangler Technical Forum 2 03-16-2009 10:55 AM
Wiper problem... will228 TJ Wrangler Technical Forum 8 08-03-2008 02:46 PM
Wiper problem Anthen27 TJ Wrangler Technical Forum 7 10-15-2005 09:05 PM
wiper problem...need help natef26 TJ Wrangler Technical Forum 2 11-11-2004 12:05 PM
