YJ Windshield hinges! - JeepForum.com
post #1 of 15 Old 05-27-2002, 08:02 AM Thread Starter
Jeepguy3401
Well I finally got new windshield hinges on my Jeep. BY THE WAY: If anyone plans on doing the switch on there YJ or maybe this is true for other models too. THERE ARE NUTS ON THE BACK OF THE BOLTS FOR THE HINGE. I didn't ralise this(Yes, I'm stupid, I know). I wasted $50 on the Sears Crafstman bolt extractor only to find that it wasn't under the normal Craftsman "You break it we replace it" warranty. HOWEVER I went to Autozone yesterday and found not only the same thing but it had more pieces with a lifetime warranty, FOR $15!!!!! Same thing with the torx bit tools. NOTICE: anyone buying the torx bit tools, DO NOT BUY LISLE BRAND. They are junk, mine broke the first time I used 'em, and they were $30, I found a set, not quite as complete, but with a lifetime warranty for like $12. Since I have had the hinges on they have hardly been visible! I've had the windsield down for 2 days now! Said and done this cost me $200. $80 for the hinge and $120 for the labor from my mechanic friend. Worth every penny. That was a pain in the butt to install! Now if I could just do something about my seat....
'87 YJ,4.2L 6cyl(rebuilding someday) On 33" Mickey Thompson Baja Claws, (unlifted, but big lift in store, when I get some $$$)upgraded clutch and brakes, broken loud stereo.(Can't imagine how that....COUGH!..WATER....happened. Haven't used a top doors or windshield in uh,.....hmm.... since midwinter? That sounds right.
Jeepguy3401 is offline
post #2 of 15 Old 06-01-2002, 08:24 PM Thread Starter
Jeepguy3401
yeah buddy! Anyone else do this?
post #3 of 15 Old 06-01-2002, 09:06 PM
Jeep Man
Sounds like a adventure!
I've felt the hate rise up in me, kneel down and clear the stone of leaves, I wander over where you can't see, inside my shell, I wait and bleed... Goodbye!
Jeep Man is offline
post #4 of 15 Old 06-02-2002, 06:55 AM
West
Are YJ hinges always this hard to replace? $120 in labor from a mechanic "friend" What do I need to look for when I replace mine?
West is offline
post #5 of 15 Old 06-04-2002, 09:08 AM
lostboy
Hey Guys....I replaced mine and I learned....lol..I had to drill most of the bolts out.The screws just stripped or the torx bit broke...finally bought torx bits made for an impact wrench...bought individual sizes..they last long time..no need to buy whole kits...when you install the new ones...coat them with some loctite blue
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #6 of 15 Old 06-04-2002, 09:36 AM
JeeperJay
Most of my hinge bolts are just spinning when I try to take them out. The ones that aren't spinning are breaking off my torx bits! I'm assuming that the weld nuts behind the bolts are just breaking loose. Is there anyway I can get to those nuts without taking the dash out?
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #7 of 15 Old 06-04-2002, 12:12 PM
Plink
Plink's Avatar
Do you have to take out the dash to get the hinges off? I want to paint mine but it sounds like it's too much effort.
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #8 of 15 Old 06-04-2002, 12:15 PM
JeeperJay
If everything is working correctly you should just be able unbolt them from the outside. But from what I've been hearing its usually not so simple. It looks like I'm gonna have to take my dash out to get to those weld nuts but I'm hoping there is some sort of trick to get them out some other way. I'm for sure not paying $120 to have somebody else do it
post #9 of 15 Old 06-04-2002, 12:31 PM
SnowMan
With my hinges, the bolts in the back wern't welded, the way I got those off was by sticking my hand up behind the speaker with a long wrench locating the bolt then having a friend unscrew the bolt. Some of my screws had to be drilled out, some ends are still stuck to the speakers magnet, they are a serious pain, took me a couple days to do them, but they look mighty fine. If the new hinges don't fit well I think this is usual, I have talked to others and they agreed, its to bad but I did buy steel horse before I found this sight and heard what crap they are and I can't agree more, thank god I work at a place where a machine shop is!
Is that you John Wayne, is this me!
SnowMan is offline
post #10 of 15 Old 06-04-2002, 07:52 PM Thread Starter
Jeepguy3401
Wow alot of response suddenly. I thought maybe this was maybe a problem only I was having. $120 was worth it the first time. But not now that I know how to do it.
post #11 of 15 Old 06-17-2013, 12:04 PM
terryjeep
i cut my hinges off around the bolts, with a 4 inch cutting wheel.
then pushed the bolts right through. first one took 1 hr.
second one took15 minutes. this is the way to go.
"Most people are about as happy as they make up their mind to be." Abe Lincoln (not to be confused with Abe Froman)
terryjeep is offline
post #12 of 15 Old 06-17-2013, 12:30 PM
terryjeep
post #13 of 15 Old 06-17-2013, 12:57 PM
OldSkull75
Im thinking about buying some mirrors that mount to the windshield frame. Will these be as much of a hassle to install?
OldSkull75 is offline
post #14 of 15 Old 06-17-2013, 01:49 PM
Rproject
1987 YJ Wrangler
Now THAT'S some archive hunting!!!!
Reviving an 11 year old thread!!!!
As for the topic, replacing windshield hinges can be a real nightmare, especially if the PO painted over the bolt heads. An ounce of prevent is worth 15 pounds of cure on this project. Taking a few minutes to look around with a flashlight to see what's on the back side of your bolts (welded nuts, nylon nuts or regular nuts) will help a lot. Also, PB Blaster is your friend. Use him until he can't be used no more.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #15 of 15 Old 06-18-2013, 10:52 AM
JMAC90YJ
JMAC90YJ's Avatar
I had to replace my windshield frame last summer, my bolts came out ok, but I did have to get my big hands behind the dash and remove the goo pucky that was covering the nuts. I put the mirror brackets on the hinges while doing it.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN THEY'RE PUSHED DOWN THE STAIRS.
JMAC90YJ is offline
Hex bolts for windshield hinges? How do I seal the hinges? ZeroGravity YJ Wrangler Technical Forum 4 05-20-2009 09:34 PM
Windshield hinges Gabagool YJ Wrangler Technical Forum 4 01-16-2009 03:47 PM
Windshield Hinges ZIMSJEEP YJ Wrangler Technical Forum 10 06-19-2006 03:24 AM
SS Windshield Hinges foy 89 YJ jmoy YJ Wrangler Technical Forum 1 11-29-2004 09:24 PM
Windshield Hinges Qcwrangler YJ Wrangler Technical Forum 12 06-29-2003 07:13 AM
