Yj Will NOT Start. Need help! - JeepForum.com
post #1 of 11 Old 09-02-2013, 06:54 PM Thread Starter
Shoelessboi
Alrighty. I have a 1991 YJ 2.5l 4 cylinder. I did a trans swap which included a starter swap. Now it won't start. It won't crank at all. The starters good. Batteries good. Fuses & relays good. The thick power cable to starter has 12v to it. The small solenoid wire when keys turned does not though! Any ideas by chance? I'm stumbled by this and really need the jeep up. I'm guessing ignition switch or something is up? Any ideas would be helpful. It's a 5 speed manual.
Originally Posted by dillonjm View Post
:The fact you even asked this question makes me want to punch myself in the face.
1991 Jeep Yj. 4cyl. 33x13.50x15 TSL Thornbirds, Super Wader Snorkel, 4" Rough Country Suspension Lift, Uniden Pro520xl Cb, 1000W Amp, 12" Rockford Fosgate P2 Sub.
Shoelessboi is offline
post #2 of 11 Old 09-02-2013, 07:03 PM
Mark05059
ok did you swap auto to manual or manual to manual or manual to auto? If it was auto to manual try grounding pin 30 on the PCM
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 11 Old 09-02-2013, 07:31 PM Thread Starter
Shoelessboi
Manual to manual.
post #4 of 11 Old 09-02-2013, 08:17 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Check the 40AMP fuse in the Power Distribution Center which is in front of your battery. If it is good, then swap out the starter relay with the horn relay. Beep the horn and try to start it up. If the horn works the starter relay was good. Last but not least turn the ignition key to the ON position then jump the two terminals with a screwdriver to see if it starts pulling the screwdriver away as soon as it does so you disengage the starter solenoid.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 11 Old 09-02-2013, 08:23 PM Thread Starter
Shoelessboi
The relays good. I haven't tried the screwdriver trick. But if that works what would be next?
post #6 of 11 Old 09-02-2013, 09:06 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Maybe the ignition module on the firewall is NG?
post #7 of 11 Old 09-02-2013, 09:10 PM Thread Starter
Shoelessboi
Firewall on drivers or passenger side?
post #8 of 11 Old 09-03-2013, 07:04 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
IIRC it is a starter relay actually under the battery on the right side of the engine compartment. See if the wire from the starter solenoid goes up to it. You can jump the relay there with the ignition in the ON position to start it up also.
post #9 of 11 Old 09-03-2013, 07:16 AM
jaycal3
As Laybackman said, I would check the starter relay. I had this issue on the hwy with my previous Jeep... I went from driving 60 to nothing at all and she wouldnt start back up. It ended up being the relay. I am pretty sure the 91 still has it, although I think in 92 or 93 they did away with it??? Maybe??
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #10 of 11 Old 09-03-2013, 08:12 AM
Que89YJ
Its the harness that you have. You probably dont have the nuetral saftey switch jumperd. Deal with the harness issue in your other thread and it will probably take care of this issue.
Que89YJ is offline
post #11 of 11 Old 09-03-2013, 10:20 PM Thread Starter
Shoelessboi
I figured the harness out today. Haven't hooked it up yet. But I will tomorrow. But there's something behind my battery. Funny looking square thing that says protective something on it.
