yj will almost die in the morning - JeepForum.com
post #1 of 16 Old 10-28-2013, 09:56 PM Thread Starter
WNUNEZJR
I wake up at 7am every day to give my lil sister a ride to school. Every mourning it will bogg down to like 200 or 300 rpms it will all most die.But it does not matter if the clutch is in or out. what could it be?
WNUNEZJR is offline
post #2 of 16 Old 10-28-2013, 09:59 PM Thread Starter
WNUNEZJR
I spelled morning wrong
WNUNEZJR is offline
post #3 of 16 Old 10-28-2013, 10:00 PM
Tuffjeeper
Is this at idle? When accelerating? Right after starting? Under Load? Deceleration?
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline
post #4 of 16 Old 10-28-2013, 10:02 PM
crackedcornish
that's OK, you spelled "bog" and "almost" incorrectly as well
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #5 of 16 Old 10-28-2013, 10:02 PM Thread Starter
WNUNEZJR
at idle and driving like at 2 or 3 mph next to all the soccer moms
WNUNEZJR is offline
post #6 of 16 Old 10-29-2013, 11:15 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
What year Wrangler , what engine , when's the last time you had a tune up ?
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 16 Old 10-30-2013, 06:30 AM Thread Starter
WNUNEZJR
1994 2.5 fuel injected. last tune up about 5000 miles ago.
WNUNEZJR is offline
post #8 of 16 Old 10-30-2013, 06:35 AM
Old4X
1990 CJ7
Vac leak, loose intake or exhaust manifold, bad sensor. Have you pulled codes yet?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 16 Old 10-30-2013, 02:03 PM
Siva283
Pull your codes before anything. You would be amazed what will show that doesnt set a hard code to turn the light on.
Ask me how I know...
Siva283 is offline
post #10 of 16 Old 10-30-2013, 08:05 PM Thread Starter
WNUNEZJR
[QUOTE=Siva283;17293074]Pull your codes before anything. You would be amazed what will show that doesnt set a hard code to turn the light on.[
Can you pull codes from a yj? Is it obd1 or 2 ive never pulled codes off a obd1.
WNUNEZJR is offline
post #11 of 16 Old 10-30-2013, 08:11 PM Thread Starter
WNUNEZJR
oooo nvm i just googled it that's pretty cool how they did that im going to do it tomorrow morning.
WNUNEZJR is offline
post #12 of 16 Old 10-30-2013, 08:29 PM
ROTTEN
Does it bog when you turn the wheel at idle?
Showing signs of multiple things but the iac hasnt been mentioned. I had the same problem. No code
I'm new
ROTTEN is offline
post #13 of 16 Old 10-30-2013, 08:39 PM Thread Starter
WNUNEZJR
yea but my tires all so rub just a lil bit
WNUNEZJR is offline
post #14 of 16 Old 10-30-2013, 08:44 PM
ROTTEN
Tires or no tires it might be an idle air control on your throttle body. Start with checking codes. Then spray around and check for vacuum leaks. Check the big line going to the brake booster well. Report back
I'm new
ROTTEN is offline
post #15 of 16 Old 10-30-2013, 09:01 PM Thread Starter
WNUNEZJR
ill get on it after work tomorrow.
WNUNEZJR is offline
