YJ Wheel Backspacing - Page 2 - JeepForum.com
 1Likes
post #16 of 33 Old 03-18-2009, 03:53 PM
chadroc
Originally Posted by dbdragracing View Post
Are those 8" wide? Thanks.
Yes, both have 8" wide wheels too.
and here's a back spacing explanation:
https://www.rsracing.com/tech-wheel.html
chadroc is offline
post #17 of 33 Old 03-18-2009, 10:02 PM Thread Starter
dbdragracing
Thanks for all the help...I just purchased a set of black Cragar Soft 8 (15x8 w/4" BS) wheels off my brother!
1999 Jeep Wrangler 4.0L 5-speed
dbdragracing is offline
post #18 of 33 Old 03-18-2009, 11:30 PM
spiicytuna
Does anyone have any pictures or know how 33's on 15x8 with 1" of positive backspacing would be?
spiicytuna is offline
post #19 of 33 Old 03-19-2009, 02:09 PM
Rproject
1987 YJ Wrangler
Don't do it. We tried to salvage our OEM aluminum rims w/ a +1" offset and you can't get the wheel to go all the way. It's going to hit the sway bar. Cragar (or similar) soft 8's or 10 D's are damn good looking rims and only cost $40-60 a rim. Suck it up and mount the 33's on steelies. It'll look great, fit correctly, and really sharpen up your ride. Just my
Rproject is offline
post #20 of 33 Old 04-07-2013, 07:39 PM
pawj112
2011 JK Wrangler
Are yall with 4"+ backspacing rubbing your leaf springs when turning?
pawj112 is offline
post #21 of 33 Old 01-27-2016, 06:18 PM
Fox1992
Originally Posted by texas_yj View Post
your stock wheels are most likely 5 1/2" (5" if you have the small steelies) and most people go sith 4 1/2" aftermarkets, you don't need more back spacing if you don't go up to a 33x12.50 or bigger, I ran 31x10.50 on stock rims for a while and never rubbed at all (at lease the springs/frame, fenders a different story )
What backspaceing would you recommend for a 33x15.50 on a 4in lift? I have pro comp wheels now but I'm not sure of the spacing, just got the jeep and I rub my leaf springs.
Fox1992 is offline
post #22 of 33 Old 01-27-2016, 06:20 PM
Fox1992
Just for a little visual assistance
Fox1992 is offline
post #23 of 33 Old 01-27-2016, 09:56 PM
rustisexpected
You dug up a seriously old post...
33x15.5 is a really uncommon street tire. First you need to decide what width wheel to run, and then decide on backspacing. But honestly to get them out far enough not to rub... Well, they are really going to be out there. Have you priced the current tires? It may honestly be cheaper in the long run to buy a set of 33x12.5's and a new set of wheels to go with them. This will solve the rubbing issue, give the jeep a lot of its driveability back, and save you some money long term.
Rusty's build thread - http://www.jeepforum.com/forum/f22/project-jermey-1806881/
rustisexpected is offline
post #24 of 33 Old 01-28-2016, 10:09 AM
Fox1992
Yeah when I got the jeep it had these on it, I know right now it's slow as ****, like I have to beg it to go over 65-70. So wild I be better off just saling them and attenpting to get a smaller wheel?
Fox1992 is offline
post #25 of 33 Old 01-28-2016, 11:06 AM
SailerMatt
You can always just try hub centric wheel spacers for now until it comes time to replace the tires and wheels.
SailerMatt is offline
post #26 of 33 Old 01-28-2016, 04:57 PM
Richard_
15x8 3.75 BS 30x9.5 tires
Richard_ is offline
post #27 of 33 Old 01-28-2016, 06:12 PM
BobStrauss
Originally Posted by Godchsr View Post
3.5 BS is the best looking by far.
All subjective, my friend. I'm glad you like 3.5 BS, but I much prefer the look of 4.5 or 4.75. I don't like the appearance of extended fender flares, nor do I like the look of tires bulging out past the flares.
To each their own.
BobStrauss is offline
post #28 of 33 Old 01-28-2016, 08:48 PM
Richard_
To each their own.
I like the added stability it creates
Richard_ is offline
post #29 of 33 Old 01-29-2016, 03:43 AM
BobStrauss
Oh, I totally understand that. A wider stance should objectively add stability. I'm was simply commenting on the appearance of it.
post #30 of 33 Old 01-29-2016, 03:58 AM
iwantaj20
Question? Even tho your flares dont cover the whole tire do you still get crud slung up AL over the side of your soft top?
US Army
Jeep lover
Stargate and Jurassic park
iwantaj20 is offline
Wheel backspacing? JeepJinx YJ Wrangler Technical Forum 11 12-21-2009 02:23 PM
Confused about backspacing and overall wheel size (What backspacing for a TJ?) uknowwho TJ Wrangler Technical Forum 21 10-03-2009 10:12 AM
wheel backspacing 05JeepTJ YJ Wrangler Technical Forum 2 09-13-2009 03:37 PM
Wheel backspacing Deezul JK Wrangler Technical Forum 4 03-23-2008 09:14 PM
17 x 9 wheel backspacing? rwmjeepjk JK Wrangler Technical Forum 3 03-20-2007 06:45 PM
