-   -   YJ Wheel Backspacing (http://www.jeepforum.com/forum/f12/yj-wheel-backspacing-732968/)
dbdragracing 03-18-2009 08:43 AM
I have a 1992 Wrangler with new 30x9.50R15 BF Goodrich AT KOs and a stock suspension. I plan on lifting it next year...after the wedding expense is behind me! But right now I plan on adding a set of black steel 15x8 wheels (guy wants to buy my stock wheels!). What backspacing should I get? Pictures would help. Thanks.
texas_yj 03-18-2009 08:46 AM
your stock wheels are most likely 5 1/2" (5" if you have the small steelies) and most people go sith 4 1/2" aftermarkets, you don't need more back spacing if you don't go up to a 33x12.50 or bigger, I ran 31x10.50 on stock rims for a while and never rubbed at all (at lease the springs/frame, fenders a different story :) )
Godchsr 03-18-2009 09:42 AM
3.5 BS is the best looking by far.
This pic is without my flares on (which I have on now)
http://i122.photobucket.com/albums/o...p/P2270028.jpg
dbdragracing 03-18-2009 10:25 AM
Are those just 8" wide? Thanks.
rustywrangler 03-18-2009 10:27 AM
I am partial to 4" BS but have had 3.75" and 4.5". I also wouldn't go past an 8" wide rim.
spiicytuna 03-18-2009 11:55 AM
Not to highjack, but now I am curious....I have been looking at some wheels that are 15 x 8" / 25.4mm offset ... how will this be with 33x12.5 tires?
yellowford 03-18-2009 12:59 PM
That will work fine with 33
chadroc 03-18-2009 01:14 PM
1 Attachment(s)
I agree. Both my YJ's have 4" BS. I think it works well. This one has 33's
dbdragracing 03-18-2009 02:03 PM
Are those 8" wide? Thanks.
PeteYJTJ 03-18-2009 03:24 PM
My YJ has 4" backspace 15x8 currently, and 35s.
http://i570.photobucket.com/albums/s...Picture109.jpg
Years ago the YJ had 4.75" backspace 15 x 8 on 33s.
http://i570.photobucket.com/albums/s...TJ/beachvh.jpg
My TJ now has 4.75 backspace 15x8 on 30s. It will get 31s when they wear out - it's my DD.
http://i570.photobucket.com/albums/s.../TJwheels1.jpg
You really can't see much from these angles though. :rolleyes: Personally I would stay with 8" wide. I don't like the low backspace wheels (<4") because it sticks the tire out too far, which looks goofy to me, and it puts more stress on your unit wheel bearings also. JMHO.
Good luck
Pete
spiicytuna 03-18-2009 03:36 PM
Wait, so 1" (25.4mm) backspacing sticks out MORE than 4" backspacing? I would totally think that it is the other way around if you hadnt said this.
Rproject 03-18-2009 03:40 PM
We've got 33 x 12.5's w/ 4" backspacing on the same 15x8 rims as Pete's black D's above. Look great and perform well. We tried to reuse the factory aluminum rims, but the backspacing (5.5 I think) was too deep, couldn't get the steering wheel to turn fully w/o hitting the sway bar. And no, we're not pulling the sway bar just yet, maybe down the road, but not yet, son is too young behind the wheel.
Rproject 03-18-2009 03:42 PM
The difference is between POSITIVE and NEGATIVE backspacing. While not a Jeep site, this link explains backspacing and offset rather well. http://www.chevellestuff.com/tech/wheel_offset.htm
A positive 25.4mm is 1" further IN towards the truck. A negative 25.4mm is 1" further OUT from the truck.
PeteYJTJ 03-18-2009 03:51 PM
Technically, the correct terminology is positive and negative OFFSET. Backspacing is usually a positive value. I don't think I've seen or heard of a "negative backspace" wheel.
To answer the question - yes, a 5" backspace sticks out LESS than a 3.5" backspace. Think of backspace as the distance from the MOUNTING SURFACE of the hub to the BACK of the wheel. So a 5" backspace would have the back of the wheel 5" inside the hub surface, while a 3.5" backspace would only be 3.5", making the wheel stick out more.
Pete
spiicytuna 03-18-2009 03:52 PM
Okay that makes sense. So a 15x8 with positive 1" of backspacing will be closer to the truck. Will this work with 33's, or look stupid, or?
The time now is 03:17 AM.
