YJ vs Early Bronco. ???s from a Bronco Fan - JeepForum.com
post #1 of 20 Old 11-18-2006, 06:48 PM Thread Starter
m1a convert
I grew up in the Moab area and had an Early Bronco. I am very familiar with them. I am now thinking of buying a Wrangler (91-93 vintage)
Here's the question.
I figure I can pick up a Wrangler for about $1500 less than a comparable Early Bronco. After doing an 8.8 axle swap I should have about the same amount of money into each rig. So we will consider price to be equal and the axles to be equivalant.
What are the strengths and weaknesses of each vehicle?
This is what I can come up with:
YJ is fuel injected, Bronco is not
Bronco has a better approach angle.
Jeep has more accesories available and cheaper parts.
Jeep will be about 20 years newer.
How do the breakover angles compare?
What about wheel base?
How well does a YJ articulate with revolvers, Z-Shackles, SOA and enough lift to clear 35s compared to the spring suspension of the Early Bronco?
How about ease of installing lower gearing in the t-case?
What else should I be weighing into the equation?
m1a convert is offline
post #2 of 20 Old 11-18-2006, 08:32 PM
demoguru
I am a ford dealer and (or I should say my parents are and I work for them now that they are retired) I have wanted an early bronco for years. However I finally cave in and bough a jeep. a 90 wrangler. The one and only reason I purchased this unit is because of the availability and price of parts. Just like having an old chevy.......you go to napa and they have everything in stock.
demoguru is offline
post #3 of 20 Old 11-19-2006, 08:49 AM Thread Starter
m1a convert
Have you ever seen the two four wheel the same rockcrawling trail?
post #4 of 20 Old 11-19-2006, 11:52 AM
Bob_R
You already answered that one.
You also asked:
Great plus.
Not necessarily, depending on what is done with each.
You answered both again.
You can't compare these unless you know the necessary info of both vehicles and what has been done with them for these measurements. There is a formula.
Jeep is shorter, works for some types of wheeling better no so on others. What are your plans to consider this question.
If you can buy (you might have to customize) parts comparable for the Bronco you can't compare.
Mine is quite easy, I have no experience with the t-case of a Bronco.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #5 of 20 Old 04-29-2010, 11:24 AM
broncoheaven
go for the bronco its a ford and if you find one with a 170 or 200 i6 still get the low end torque and 22 miles per gallon on 33s and will have a 40 year motor miles dont mean much with the i 6s just bought my 2nd eb and couldnt be happier i do own a xj as well still rather have the eb
broncoheaven is offline
post #6 of 20 Old 04-29-2010, 11:27 AM
broncoheaven
i will say that jeeps are hard to kill besides the water pump lol 3 jeeps everyone needed a water pump at 100 k my 72 bronco is on it orig everything but carb rebuild and i bet shes pushin 300k miles
post #7 of 20 Old 04-29-2010, 11:29 AM
Peltboy25
If you like a manual trans, Bronco shifter is in the column. Nobody wants that. I know it can be modified, but there ya go. I'd personally kill for an early Bronco with a 302 and an auto. I just love 'em. But there are a lot fewer of them than Jeeps out there.
Drive like you're going somewhere.
Peltboy25 is offline
post #8 of 20 Old 04-29-2010, 11:31 AM
jeepin64
2010 JK Wrangler
Yj yj yj yj yj
jeepin64 is offline
post #9 of 20 Old 04-29-2010, 11:42 AM
JohnFM3
My buddy has a 70's bronco. And as much as he loves it, it doesn't seem to compare to the many friends Jeep Wrangler.
I guess he big thing to think about is "Can you fabricate Everything?". If you dont like the way the suspension works on the YJ, you can buy a LONG ARM kit to install, and in some cases find bolt on kits. I have heard of someone using 4 link long arms and Leaf Springs in stead of coils.
This is where owning a jeep lends itself a long way. There is a LARGE following, and you can find most parts you would ever want or need. And if its not been done, you could find someone that would help you try it out. And great forums such as this with plenty of info.
Good Luck on your decision,
John
John Moore ~ Real Men Still Crawl...
97 XJ (Diablo) 4.0L H.O. w/AW4 4sp Auto Dana 30/Chry 8.75 2.5 inch Flowmaster Exhaust 4 inch Lift w/ 32inch tires & RS5000 Shocks
92 YJ (BOSS) 4.0L H.O. w/AX-15 5sp Manual, 231 TCase, Dana 30/8.8 (3.73) 2.5 inch Flowmaster R.E. 2 inch lift and 2 inch body lift for CJ clip
XJ
YJ
JohnFM3 is offline
post #10 of 20 Old 04-29-2010, 11:43 AM
broncoheaven
im not jeep smashin its the only other thing i will drive but my eb i have a 72 and a 73 bronco and a xj that has been beatin and she likes it xj is my daily driver/family car wont send my wife out in a car that wont bring her back
post #11 of 20 Old 04-29-2010, 01:24 PM
QuantumYJ
I want one of each. If you can find a DECENT EB for around the same price as a YJ in Idaho I might have to take a road trip up there. Around here, if it's worth restoring they're over $8,000, $10,000 and up if they've been restored even a little and if you find one for much less than that it's usually junk, only good for parts. I overpaid for my YJ as it is (everything is high here seems like) but if I could find a Early Bronco for the same price / condition I'd buy it.
Still if I had to choose only one it would be a hard choice. I like the "one of a kind" aspect of the EB, there's a YJ/TJ/JK around every corner. As far as capability the EB wins, stock, on axles etc., the YJ on engine, electrical, etc. sophistication. But who cares, you wont leave the stock motor in the EB (or you will rebuild, update) and you won't leave the D35 etc. in the YJ so I think it comes down to a simple personal choice.
I've been on the internet too much lately. Now, even I'm beginning to think that "breaks" are what you use to stop your Jeep.
QuantumYJ is offline
post #12 of 20 Old 04-29-2010, 01:36 PM
shadowulf
I had a '66 eb and loved it. I have a '90 yj now and love it. They both have their advantages. I'd say find a 4.0L yj, hunt around for a front axle from a 2.5L (4.11 gears) and a 8.8 with 4.11 and a LSD. You can run 33's and still have a few $$ for other bits and pieces.
shadowulf is offline
post #13 of 20 Old 04-29-2010, 02:12 PM
MLJeeper
MLJeeper's Avatar
Originally Posted by m1a convert View Post
So we will consider the axles to be equivalant.
If the EB 9" is 28 spline no, if 31 spline yes. Most EB 9"s ive come across are 28 spline. I own 2 of them. Doesnt cost alot to upgrade though. I like the EBs. Buddy of mine has two as well. One he butchered and made into a monster on rocs and one he restored.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #14 of 20 Old 04-29-2010, 05:14 PM
linusb
Early broncos are art. But you're talking a very old vehicle. Too much maintenance. I'm venturing to guess that Jeep parts/accessories are more plentiful and cheaper. Go Jeep.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #15 of 20 Old 04-29-2010, 05:47 PM
djsmith1174
I love EBs as much as I love Jeeps. Why they changed that body style so much for the second generation is beyond me. I'm sure it had to do with platform sharing with Ford trucks.
I think it all comes down to use and budget. If your going to wheel it really hard and want to be able to repair it cheaper, I would say the Jeep will be the way to go. You'll likely spend more to get the EB up to snuff with the YJ. Just due to parts availability. That being said, both are extremely capable trail vehicles that look very good.
djsmith1174 is offline
4.0 I6/ NP435/ early model bronco dana 20 TC combo OSYJ93 YJ Wrangler Technical Forum 4 08-25-2009 01:19 PM
Early Bronco 44 in YJ Randy.YJ YJ Wrangler Technical Forum 8 05-22-2008 07:43 AM
Early 70s Bronco Solid Axles BigMikey YJ Wrangler Technical Forum 12 01-07-2007 12:50 PM
Early Bronco Axles jeepteejay TJ Wrangler Technical Forum 5 09-30-2006 08:35 PM
Early Bronco Axle Swap in a TJ JeepNazi101 TJ Wrangler Technical Forum 5 07-11-2006 03:35 PM
