YJ to V8 ZJ Steering *confused* - JeepForum.com
post #1 of 22 Old 04-03-2013, 03:22 PM Thread Starter
GuitarDude6567
I recently installed a new suspension to my YJ (4" Rough Country w/MORE 5/8" Shackles). I've also been replacing just about every bushing as well as motor and trans mounts at the same time. Now it is time to get to the steering and get her back on the road! I was going to just order all new parts instead of just getting new tie rod ends because I wanted an all new appearance and its not much more money for the bar and all.
So I did some research and it seems all aftermarket kits (Currie, Rusty's, Rugged Ridge) all have some kind of downfall and some issues. Plus they're more expensive. So I decided to go with a complete setup from a V8 ZJ instead of just getting all new stock YJ parts. Seemed to be the best bang for the buck and parts can be found at the auto store in a pinch. Then I realized how different the setup is and it may be difficult to even get this close to right before I get to the alignment shop. Did I screw up or is this a good bolt on upgrade? Should I have gotten a TJ drag link (pitman arm to passenger knuckle) and a V8 ZJ tie rod (driver knuckle to drag link)? Or is there even a difference? Any tips on what to measure to make the swap close to drive-able before I get an alignment? I already have the drop pitman arm from Rough Country installed. I'm ready to get back on the road!! Thanks and cheers!
'94 YJ SAHARA - 4" SUA, 5/8" BOOMS, 1" MML, SYE, ECGS 8.8 OX, AUSSIE D30 W/TJ SHAFTS, 33x12.50x15
GuitarDude6567 is offline
post #2 of 22 Old 04-03-2013, 03:59 PM Thread Starter
GuitarDude6567
*BUMP* Help! I'd like to either try to install this tonight or return and order the correct parts. Am I better off ordering stock YJ parts?
post #3 of 22 Old 04-03-2013, 04:05 PM
JohnnyZJ
ZJ steering is the 'inverted Y' setup and stock YJ is the "inverted T" setup. they are quite different. if i recall and i'm not sure, but the V8 setup will hit the front spring and not be very happy.
stock YJ stuff is just as strong as the stuff. at least up here it is. when i replaced steering on the YJthe tie rod and drag links were all solid steel, one piece, not hollow tube (like the I6 and cherokee steering) only reason V8 stuff is 'stronger' is because its solid.
i've bent up the ZJ V8 steering pretty bad though. (on my ZJ)
i'd go stock YJ stuff, or upgrade to something aftermarket
07' JKUR rollin on 35s
JohnnyZJ is offline
post #4 of 22 Old 04-03-2013, 04:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The problem is you aren't talk enough to go with a hi steer and you will only shrink from here on out with those springs. Get a stock Yj replacement and roll with it.
Luck Favours The Prepared
Anticanman is offline
post #5 of 22 Old 04-03-2013, 04:20 PM Thread Starter
GuitarDude6567
Thanks guys! I was afraid you were going to say that. Ugh, hopefully I can get new parts ordered and here by the end of the week.
I'm going to be an aggressive wheeler with 33x12.50's. Should I keep it stock and simple or look into an upgrade? Rusty's or Currie?
post #6 of 22 Old 04-03-2013, 04:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Depends where you're wheeling. If you run the risk of bending your tie rod then beef it up. The Rusty's kit is pretty decent. I have the rugged ridge HD kit and its asi-asi.
post #7 of 22 Old 04-03-2013, 08:45 PM Thread Starter
GuitarDude6567
Whats "asi-asi"? May be obvious but i don't know. I'm going to be doing whatever trail I can. I've got an 8.8 standing by lol.
I've heard really bad things about the Rusty's. It looks nice. I'm even semi-local to where they're based in Rainbow City, AL. Could go pick one up instead of waiting for shipping.
Seems like most people like the Currie. I'll look into the Rugged Ridge as well. Thanks for the replies!
post #8 of 22 Old 04-03-2013, 10:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Asi-asi is Spanish for so-so. I need to speaky more Engly instead of mixing the two. Can you forgive a brown person?
post #9 of 22 Old 04-03-2013, 11:26 PM Thread Starter
GuitarDude6567
Ah. Well the Rugged Ridge is what I think I've decided to go with. I'm looking at $209 shipped for the Rugged Ridge or $140 shipped for stock. Since you own it, is it worth the nearly $70 difference?
My only concern is that my Rough Country dual steering stabilizer kit may not work if the Rugged Ridge drag link is a greater diameter than stock.
What steering stabilizer do you run on your RR steering?
post #10 of 22 Old 04-03-2013, 11:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Rugged ridge includes a stabilizer bracket for a single stabilizer. You don't need dual stabilizers. The RR kit is the same geometry as the stock setup just with a lot more heft and one ton tie rod ends. It is beefy but has no upgrade in regard to geometry.
post #11 of 22 Old 04-03-2013, 11:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sorry. You asked which stabilizer I run.
Its a white one.
post #12 of 22 Old 04-04-2013, 12:26 AM Thread Starter
GuitarDude6567
I realize most steering stabilizers are useless and so is this dual one I'm sure. I just got RC to throw it in for free so why not throw it on there. Its driving no worse now without one. Well my only question then is what would you do if you had it to do over again? Stock Crown Auto products or the RR HD kit? $140 vs $210.
post #13 of 22 Old 04-04-2013, 12:28 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's a good question. Lemme ponder it a spell.
post #14 of 22 Old 04-04-2013, 01:12 AM Thread Starter
GuitarDude6567
Haha. Let me know what you think. I need to order in the morning.
post #15 of 22 Old 04-04-2013, 10:06 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How do you feel about Rusty's?
