YJ Upper Shift lever removal - JeepForum.com
post #1 of 6 Old 01-19-2011, 05:32 PM Thread Starter
sshearon
The shift lever on the YJ is actually two pieces. The piece that seats into the top of the AX5 transmission, and a top section that looks like it slides onto the bottom section. Can anyone tell me how to get the two sections apart? I put in a new transmission and the new transmission has the lower section with it, and it is shorter than the original. So, I need to get them apart so I can put the old top section on the new bottom section (that seats into the top of the transmission.)
sshearon is offline
post #2 of 6 Old 01-19-2011, 08:43 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
From a FSM " (b) Reach up and around transmission case and
unseat shift lever dust boot from transmission shift
tower (Fig. 6). Move boot upward on shift lever for
access to retainer that secures lever in shift tower.
(c) Reach up and around transmission case and
press shift lever retainer downward with your fingers.
Turn retainer counterclockwise to release it.
(d) Lift lever and retainer out of shift tower"
Hope this helps you...
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 6 Old 01-19-2011, 11:35 PM
Opihi59
from here it gets rough
Opihi59's Avatar
http://www.jeepforum.com/forum/f12/s...hifter-513891/
Give this a try.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 6 Old 01-20-2011, 09:05 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
It would be much easier to remove the stubby shifter and replace it with the full one. Its as simple as unlocking the lockring and pulling out the shifter.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 6 Old 01-20-2011, 09:47 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Not all lower shifters are the same length. You might have to swap out the whole tower. To answer your question though, that square bulb thing on the lower end of the hand held shifter part is just press fit onto the part sticking out of the trans. They get good and stuck. I've done best by doing the lock ring thing mentioned above then take the two-piece thing to a bench vice. I clamp the lower part in the vice right near the upper part, so the upper part is maybe 1/8" from the vice jaws. I then use a small pry bar or large screwdriver to pry off the upper part against the vice jaw. It works every time (for me anyway).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 6 Old 01-20-2011, 09:56 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thanks for the clarification, didn't know that
-Matt
White '94 YJ Sport
UltimatE is offline
removal , shifter
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 07:31 AM
BA10 shift lever removal when in neutral ScottsYJ YJ Wrangler Technical Forum 5 06-06-2009 06:54 PM
Gear shift lever removal Instructions wanted Rich8earnhardt YJ Wrangler Technical Forum 4 02-26-2009 09:03 PM
How to separate upper shift lever from lower shift lever??? rgs112 YJ Wrangler Technical Forum 3 08-11-2008 05:59 PM
Shift Lever Trevaller YJ Wrangler Technical Forum 6 08-17-2007 04:53 AM
