YJ U-joints go out - JeepForum.com
post #1 of 16 Old 03-17-2013, 09:16 AM Thread Starter
john_pettit2
YJ U-joints go out
I have a 1992 Yj jeep wrangler with a rough country 4" lift kit and 2" body. I can't keep my u-joints to stay good for over 2 months. They keep breaking on me. Iv been doing a lot of research on here and it seems like the best thing to do it buy new perches and weld them on to make sure the pinion angle is correct. I do not have a SYE kit yet but do plan on buying one soon. The pinion does not look to be that much off anyhow. I do not think new perches will fix this problem. I will post some pictures up in a little while so you guys can tell me what you think.
john_pettit2 is offline
post #2 of 16 Old 03-17-2013, 09:29 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pics?
And welcome!!
Luck Favours The Prepared
Anticanman is offline
post #3 of 16 Old 03-17-2013, 09:32 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
4" of lift and stock rear axle/drive shaft setup, my guess is bad driveshaft angles. SYE, CV shaft + new perches to point the pinion at the TC output shaft is the way to go.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 16 Old 03-17-2013, 10:53 AM Thread Starter
john_pettit2
it has the bars that go between the frame and skid plate to drop the transfer case. Other than that yes it is stock rear axle and drive shaft.
post #5 of 16 Old 03-17-2013, 10:54 AM Thread Starter
john_pettit2
Pics will be posted around 3:00,
post #6 of 16 Old 03-17-2013, 01:33 PM Thread Starter
john_pettit2
best pic i can get right now
post #7 of 16 Old 03-17-2013, 01:47 PM
jbolty
jbolty's Avatar
from that picture it looks like the pinion is way too high for that type of drive shaft. Best thing to do is get the SYE on there, get rid of the T-case drop and set a good angle. You will need to either buy or make a double cardan drive shaft.
Here's the two different types and angles
jbolty is offline
post #8 of 16 Old 03-17-2013, 01:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pinion looks a tad high especially for that type of driveline. Bet a little axle wrap on takeoff will snap them.
post #9 of 16 Old 03-17-2013, 01:56 PM Thread Starter
john_pettit2
I just ordered 2" add a leaf today for it. After I add that I was thinking it will definitely be off but when I get the SYE kit (this summer) why would it be better to take out the transfer case drop? Wouldn't want to weld the perches in and then buy the kit and have to reweld them back on.
post #10 of 16 Old 03-17-2013, 03:30 PM
Gage56
ok not to thread jack , so you guys are saying " the pinion u-joints " should be sightly lower than the t-case joints for it to be proper ?
1992 YJ
Gage56 is offline
post #11 of 16 Old 03-17-2013, 03:38 PM
pasinbuy
At that angle, when you accelerate you are way high. Then you break U-joints. Even just a light acceleration will bring you to high on the angle.
One more thing, do not paint your drive shaft. Bad move, may cause vibration.
pasinbuy is offline
post #12 of 16 Old 03-17-2013, 03:53 PM Thread Starter
john_pettit2
So for my set up right now you think the rear yoke needs to come down?
post #13 of 16 Old 03-17-2013, 06:08 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
May just be picture angle, but is there any slip yoke remaining outside the transfer case? Looks to me like the drive shaft is too long too.
-Matt
White '94 YJ Sport
UltimatE is offline
post #14 of 16 Old 03-18-2013, 12:36 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
from the way your picture looks your pinion angle is way to high. It needs to be parellel to the tc output.
Here is an explanation as to why.
http://www.pirate4x4.com/tech/billav...ft/index2.html
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
87TPIYJ is offline
post #15 of 16 Old 03-18-2013, 12:44 PM
SeanB95YJ
yes, lower your pinion angle.... looks like you have shims installed which are tilting it up... remove them and either leave them out or if necessary, install smaller shims
save those shims though because, at least in that camera angle, it looks like you currently have a good pinion angle if you were running SYE/CV shaft
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
