Yj Turn Signal Issue - JeepForum.com
post #1 of 8 Old 10-16-2013, 12:40 PM Thread Starter
Tylerrr08
Heyy guys did a full rebuild of the steering collum and put everything back togethere but for some reason I can turn my left blinker on but it doesn't allow the arm to pop it back so I can turn right or left instead it sticks and comes straight out of the slot trying to go back to right with my turn signal. Any ideas or anything! thnks!
Tylerrr08 is offline
post #2 of 8 Old 10-16-2013, 03:33 PM Thread Starter
Tylerrr08
Bump
post #3 of 8 Old 10-16-2013, 03:51 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I dont understand exactly what you are talking about, but I installed a switch from Napa and it acted funky. I had to file the housing down around some edges to get it to seat properly, and I also had to mess with the torque of the bolts so it would line up correctly with ecerything. It was a pain.
Randonexplosion is offline
post #4 of 8 Old 10-16-2013, 05:50 PM Thread Starter
Tylerrr08
Basically the actuator arm that goes on the multifuction switch from the widshield lever is slipping so when I go from the left turn on the lever it slips off becoming limp
post #5 of 8 Old 10-16-2013, 05:51 PM Thread Starter
Tylerrr08
Not allowing me to cancell the left blinker or turn the blinker to the right
post #6 of 8 Old 10-16-2013, 07:14 PM
rubisean
is nipple of the cancel cam that the horn contact goes to at the 1o'clock when the steer wheels are straight your shaft is correct, if it is at the 7 o'clock position your shaft is 180* 0ut.if it is not that then it is the small spring on the turn signal switch is missing, there are two on one the left side and one on the right side
rubisean is offline
post #7 of 8 Old 10-17-2013, 03:00 PM Thread Starter
Tylerrr08
So made some calls and I guess our local autozone gave me one that is for a non tilt steering so hopefully thatll be the difference ill let you all know!! I doubt it but hopefully
post #8 of 8 Old 10-18-2013, 07:53 PM Thread Starter
Tylerrr08
Im stuck i have no idea what to do!
