YJ with truck shocks for a 4in lift - Page 8 - JeepForum.com
post #106 of 122 Old 01-21-2014, 08:42 PM
tecksjeep
Wait for it......
tecksjeep's Avatar
What gauge steel did you use for the flat parts, and what diameter tubing?
tecksjeep is offline
post #107 of 122 Old 01-21-2014, 08:51 PM Thread Starter
ashland82391
Don't know what gage but it was 1/8". Tube was 1.25 with .120 wall.
ashland82391 is offline
post #108 of 122 Old 01-21-2014, 09:06 PM
tecksjeep
Wait for it......
tecksjeep's Avatar
Thanks man I will probably take a stab at it. Steel is cheap =)
post #109 of 122 Old 01-21-2014, 09:06 PM Thread Starter
ashland82391
Good luck. Let me know how the shocks workout
post #110 of 122 Old 01-21-2014, 10:00 PM
GrantYJ
Just FYI, 10 ga is the closest to 1/8".
I used 12 ga all the flat metal for my tube fenders.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #111 of 122 Old 01-21-2014, 10:02 PM Thread Starter
ashland82391
Thanks for the info
post #112 of 122 Old 01-22-2014, 12:34 AM
tecksjeep
Wait for it......
tecksjeep's Avatar
Hey Ashland, did you ever figure out a shock for 6" of lift? you talked about doing that on your thread since you couldn't get max flex with the other shocks
post #113 of 122 Old 01-22-2014, 12:41 AM Thread Starter
ashland82391
I actually did find shocks for the rear but never went threw with it and forgot to save the info. As for the front, these might be the longest stock production shocks they make with the mounting that we need. I'll find the rear shocks again though.
post #114 of 122 Old 01-22-2014, 06:45 PM
tecksjeep
Wait for it......
tecksjeep's Avatar
Hey man, maybe it would be better to PM you about this but I was talking to a guy about getter a bender today to make some fenders. He asked what I wanted to bend, pipe or tubing? isn't it all the same haha. i'm sure that it is pretty simple to bend "pipe". He seemed like he was making a big deal out of something easy. just get it from the steel yard right?
post #115 of 122 Old 01-22-2014, 08:00 PM Thread Starter
ashland82391
Pipe, what I used isn't as strong as tube(DOM) so some benders have a hard time bending tube. There is nothing wrong with using pipe though as long as the wall is thick enough. My tube fenders, made from pipe, have proved there self time and again. My uncle uses pipe, thick wall, in his race car roll cage and it takes a beating. He's rolled it, smashed it, never has the pipe failed or bent.
post #116 of 122 Old 06-20-2014, 03:35 PM
bogi94yj
Just found this thread.THANK YOU! It's exactly what I was looking for.
Sorry, you may have already covered this, but how did you do the leafs on the 4 inch lift?
Stock front and rear 99 blazers or did you bastard them?
Brand new jeeper and trying to build my off-road yj on a budget...most bang for the buck
Thanks again
bogi94yj is offline
post #117 of 122 Old 02-02-2015, 07:20 AM
Follyjeep
Hi,im new here ,i find in a shop 4 shocks for 60 dollars,the name is gabriel pro guard ,the number is 61612,now my questyon is if i can use the four shocks or in the front must be diferent? Thanks
Follyjeep is offline
post #118 of 122 Old 02-02-2015, 07:38 AM
tecksjeep
Wait for it......
tecksjeep's Avatar
Read through this thread. It has all the info and part numbers you need
5.7 Vortec, D60 front w/ detroit,14 bolt rear w/spool. 16" FOA Coilovers in rear ORI struts in front, Barnes Enduro Joints, Daves custom boat sides/rear armor.
Check out my build here!
post #119 of 122 Old 02-02-2015, 09:07 AM Thread Starter
ashland82391
You'll find your info on page 1
post #120 of 122 Old 02-04-2015, 05:27 AM
Follyjeep
Thanks guys, i all ready buy, two from auto zone in56 bucks and two from some shop in san diego in 32 include shipment, my last question, after two years that u use, is work good?thanks again!!!
Thoughts about this lift?? Skyjacker 4" Economy Lift Kit with Hydro Shocks Enimo TJ Wrangler Technical Forum 31 03-05-2012 06:24 PM
will Rancho RS9000 (5-6in lift) shocks work with a Rough Country (4in lift) kit? Arron TJ Wrangler Technical Forum 1 04-02-2011 01:12 PM
best shocks for 4inch lift, 1 inch body lift epeck87 TJ Wrangler Technical Forum 0 04-05-2009 01:49 PM
jeep lift kit install on truck-u 76flh Wrangler General Discussion 19 11-17-2008 04:03 AM
2 inch lift - Shocks or no shocks?? BuzzHog JK Wrangler Technical Forum 5 03-25-2008 03:58 PM
