YJ with truck shocks for a 4in lift - Page 4 - JeepForum.com
post #46 of 122 Old 04-27-2013, 02:07 PM Thread Starter
ashland82391
Originally Posted by 4.7stroker View Post
Thank you for doing the grunt work.
I went with the Monroe's because that is what O Rilley's had.
My old shocks were dead and these seem to work just fine for my needs.
Dwayne
No problem man!
ashland82391 is offline
post #47 of 122 Old 07-14-2013, 01:02 AM Thread Starter
ashland82391
Found that the front shocks will work for a tj as well. We just needed to swap out the bottom bushings/mount.
I will find out tomorrow of the rears will work too. I'm testing them out on my buddys Jeep since all his shocks are junk.
post #48 of 122 Old 07-14-2013, 04:32 AM
jason280
I did a little research, and I am using a set of Gabriels from a Ford (rears from a 4x4 F150) as front shocks in my '94 YJ. I'm running 3.5" springs with 1/2" boom shackles, and so far so good. I haven't checked full flex, but ride is comparable with my stock springs and shocks.
I did a lot of internet searches, and was able to find a Gabriel shock that had comparable specs to the (length, travel, etc) shocks found in most 4" lifts. Now, I did intentionally go with a cheap shock just in case I ran into any problems, that way I wouldn't be out much. In fact, I think I'm into the pair for less than $30 shipped.
None
jason280 is offline
post #49 of 122 Old 07-14-2013, 05:03 AM Thread Starter
ashland82391
this thread has all that info on the front page.... Part numbers, measurements, everything
post #50 of 122 Old 09-13-2013, 12:48 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Ashland, in your search was the 82147 for the rear (off the 74 f250) the only one you found that would work?
I have advance, autozone, oriellys, napa, carquest and a noname parts store and none of them have it, or can even get it for 4 days.
I kinda need a today solution lol
-April '14- YJoTM- June '15]
The_Goob is offline
post #51 of 122 Old 09-13-2013, 01:56 PM Thread Starter
ashland82391
Sorry, that's the only one. my friend and I both had to wait about 3 days for the rears.
post #52 of 122 Old 09-13-2013, 03:02 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I just found an advance that has them in a half hour away, guess Ill be driving! Thanks for the reply.
PS did you say you ran these before you lifted? all i have is 1" body, and 6" shackles (+1") just wondering if these are gonna bottom out before the bumpers hit
The_Goob is offline
post #53 of 122 Old 09-13-2013, 03:18 PM Thread Starter
ashland82391
they should be fine, just don't do any jumps lol
post #54 of 122 Old 09-14-2013, 07:01 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
They work great, thanks for the idea! my stock shocks were so blown, so got a better ride and got my flex back.
You sir, get a cookie!
The_Goob is offline
post #55 of 122 Old 09-15-2013, 05:14 AM Thread Starter
ashland82391
Woohoo!
post #56 of 122 Old 09-23-2013, 04:17 PM
Carlos14
Over 1 year on mine and still riding and flexing great.
Luck Favours The Prepared
Carlos14 is offline
post #57 of 122 Old 09-23-2013, 05:21 PM Thread Starter
ashland82391
Ditto, glad your enjoying it!
post #58 of 122 Old 09-23-2013, 08:12 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
I think I know the answer from reading this entire thread but...
Just to make sure, this shock setup should work with my 2" lift?
-John-
johnboy68 is online now
post #59 of 122 Old 09-23-2013, 08:25 PM Thread Starter
ashland82391
Yup
post #60 of 122 Old 09-24-2013, 03:38 AM
SPYDERYJ
1987 YJ Wrangler
I have a 6" shackle lift on my '87 YJ (how I got it from PO) but I'm not sure if it's stock shocks or not but this thread caught my eye. Would this shock swap give me more flex or give me a crazy dangerous ride? Still new to jeeps but all the posts I've seen in this thread don't mention shackles as large as mine.
1987 YJ with 6" shackle lift on 33x12.50R15's.
SPYDERYJ is offline
Thoughts about this lift?? Skyjacker 4" Economy Lift Kit with Hydro Shocks Enimo TJ Wrangler Technical Forum 31 03-05-2012 06:24 PM
will Rancho RS9000 (5-6in lift) shocks work with a Rough Country (4in lift) kit? Arron TJ Wrangler Technical Forum 1 04-02-2011 01:12 PM
best shocks for 4inch lift, 1 inch body lift epeck87 TJ Wrangler Technical Forum 0 04-05-2009 01:49 PM
jeep lift kit install on truck-u 76flh Wrangler General Discussion 19 11-17-2008 04:03 AM
2 inch lift - Shocks or no shocks?? BuzzHog JK Wrangler Technical Forum 5 03-25-2008 03:58 PM
