YJ with truck shocks for a 4in lift - Page 2 - JeepForum.com
post #16 of 122 Old 04-17-2012, 03:44 PM Thread Starter
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Originally Posted by booboowv77 View Post
Great info! The only problem I see is when you flex it being all the shocks have 2 inch less compressed length it would limit your up travel when on uneven ground. Might not be that big of deal but just a thought. Do you have any pics of it flexing to see how it sucks up the down tire?
absolutely no problems flexing with the bastard pack and shocks. I did this just for you today. the edge is over 1 and a half foot right were its at and I could have gone even further but i was by myself and didn't want to tip. (im not very experienced with flexing.
ashland82391 is offline
post #17 of 122 Old 05-08-2012, 09:15 PM
booboowv77
Be careful on the rear shocks and make sure that the auto parts store gives you the ones with 2 eyelets and NOT the ones with the stud and one eyelet, or better off just ask for the ones for a 91 grand wagoner (same shock)
I have been fighting with the idiots at the auto parts for about a week now first off they had to special order them, and they where the ones with the studs. Then they reordered and I got 2 different shocks with the same part number on the boxes but the compression rate is different on them. Now I have to run to the next town tomorrow to get Hopefully the correct ones and finally get them installed.
The fronts do feel much better though. I would defiantly recommend extended brake lines, because mine where tight with the factory shocks and with the longer shocks I got 3 inches more drop in the front when flexing so the factory would have pulled or snapped.
booboowv77 is offline
post #18 of 122 Old 05-08-2012, 09:17 PM
booboowv77
absolutely no problems flexing with the bastard pack and shocks. I did this just for you today. the edge is over 2 foot right were its at and I could have gone even further but i was by myself and didn't want to tip. (im not very experienced with flexing.
Looks good Thanks
post #19 of 122 Old 05-09-2012, 05:45 PM Thread Starter
ashland82391
For the brake lines i just relocated them to the bottom of the frame, was super easy and gave me a ton on brake line to work with. Also didnt cost me a thing!
post #20 of 122 Old 07-10-2012, 10:40 AM
koesdibyo
For those fronts (rears out of a f150), does it matter if its a 4WD or 2WD vehicle? Im trying to find a spreadsheet to tell me f150 shock sizes, but cant come up with anything (not the greatest researcher either :P).
Anyone know if what years the f150 rear shocks would work (having a tough time tracking down a specifically 1997)
koesdibyo is offline
post #21 of 122 Old 07-10-2012, 07:31 PM Thread Starter
ashland82391
it has to be 97 and 4wd i just went to autozone
post #22 of 122 Old 07-10-2012, 10:11 PM
superj
so i guess the weight of the pick up doesn't matter on the shocks? i thought shocks were made having to do something with the weight of a vehicle too?
i am asking because i really don;t know, not trying to put down this because i have always thought of doing this but was not sure since the weight differences
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #23 of 122 Old 07-11-2012, 12:35 AM Thread Starter
ashland82391
there might be a little variation between shocks but i haven't been able to notice anything what so ever. All a shock does is prevent the vehicle from bouncing up or down uncontrollably. the shock does not lift a vehicle.
post #24 of 122 Old 07-11-2012, 07:59 AM
superj
I understand but I thought heavier vehicles required higher pressures I the tube?
Either way, it appears to work fine. It didn't make the ride more harsh?
superj is offline
post #25 of 122 Old 07-11-2012, 01:27 PM Thread Starter
ashland82391
they probably do have more pressure then other shocks but I haven't noticed it. I went straight from stock gabrials to these gabrials and didn't feel any difference. Plus i dont think its possible to make the ride anymore harsh
If your going to do this i wouldnt be worried because if you were to buy rough country or rancho shock it would be stiffer then any gabrial shock and they flex great!
post #26 of 122 Old 08-26-2012, 10:13 PM
Ksyrium
1987 YJ Wrangler
I did this last week, I also got about 2" of Lift.
I went to a pick-n-pull, and got the leaf springs out of a '99 blazer - which had 4 leafs on it, so I didn't have to cut any. And I still have the main leafs if I want to make any changes, I just have to cut them to the length I want.
I'm planning on getting the rear shocks this week. I think the base Grabiel shocks will be an upgrade from the 25 year old stock shocks that are on it....
Thanks for the info!
ΜΟΛΩΝ ΛΑΒΕ
Ksyrium is offline
post #27 of 122 Old 08-27-2012, 01:15 AM Thread Starter
ashland82391
no problem
post #28 of 122 Old 11-14-2012, 03:54 PM Thread Starter
ashland82391
I guess its about time I do a little update. That shocks are still doing great. I recently bout a pair of 3.5 inch fabtech leaf springs, which with my shackles I netted about 5" of lift in my rear. The shock are still good for it but are limiting me a little at max flex, so Pretty soon here I will be doing another search and see If I can find shocks good for a 6 inch lift. here is the latest flex results with the fabtechs.
furthest up the ramp ive gotten so far. I could have gone further if the shocks weren't limiting me, my back drivers tire started to lift off the ground. I could use some bump stops too. Still well worth the price and the research.
post #29 of 122 Old 04-06-2013, 06:54 PM Thread Starter
ashland82391
Updated with part numbers.
post #30 of 122 Old 04-06-2013, 07:25 PM
flcracker
Thanks for the write up.... I have a leaking shock in mine with a 4" lift I think, thats the way I bought it anyway so I will likely pull one off and measure it to be sure.
The part numbers from the original post are correct for the 4" lift right??
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
Thoughts about this lift?? Skyjacker 4" Economy Lift Kit with Hydro Shocks Enimo TJ Wrangler Technical Forum 31 03-05-2012 07:24 PM
will Rancho RS9000 (5-6in lift) shocks work with a Rough Country (4in lift) kit? Arron TJ Wrangler Technical Forum 1 04-02-2011 02:12 PM
best shocks for 4inch lift, 1 inch body lift epeck87 TJ Wrangler Technical Forum 0 04-05-2009 02:49 PM
jeep lift kit install on truck-u 76flh Wrangler General Discussion 19 11-17-2008 05:03 AM
2 inch lift - Shocks or no shocks?? BuzzHog JK Wrangler Technical Forum 5 03-25-2008 04:58 PM
