YJ with truck shocks for a 4in lift - JeepForum.com
post #1 of 122 Old 04-09-2012, 01:03 AM Thread Starter
ashland82391
This thread will tell you what trucks you can take shocks from and put on the YJ for a 4inch lift. This is a great way to stay on budget and have shocks that are the right length for your lift.
I started looking around jeep forum last week trying to find this very thread but couldnt so I did all the reserch and figured Id post it on here. The reason I went with truck shocks is because I had bought stock yj shocks from autozone a couple of months eailer and then I decided I wanted to do and lift and I didnt want to weast the money I had just spent on my shocks. Autozone agreed to swap them out, so I went and did the reaserch and figure out what shocks i needed then I swapped them.
For those who cant just swap your old shocks out this is still the cheaper way to go with out sacrificing shock performance ALL 4 SHOCKS COST ABOUT 85$ all together.
Here's the info and a few pictures.
Based on this web site http://www.monroe.com/assets/downloa...engthSheet.pdf
I have found that 1997 ford f150 rear shocks for the front on the yj are just about perfect and mounting is almost exactly the same, but ill be using Gabiral shocks so the lengths very a little from the monroes. I especially like the fact that the f150 shock has 12.03 inches of travel!
YJ stock specs: Compressed 14.5 in
Extended 24.375 in
Travel 9.8 in
(Gabriel Pro Guard Shocks)
97 F150 specs: Compressed 16.3 in
Extended 28.3 in
Travel 12.03 in
Part number #61612
Here is what I found for the rear. 1974 ford F250 shocks will mount up perfectly and have the exact lengths I want as well.
YJ stock specs: Compressed 11.8 in
Extended 18.3 in
Travel 6.5 in
(Gabriel Guardian Shocks)
74 F250 specs: Compressed 13.8 in
Extended 23.2 in
Travel 9.3 in
Part number #82147
I received the shocks the next day and they mounted up perfectly just like the web site's measurements said. Ive been driving them around for a couple days and I have absolutely no complaints. This beats the heck out of spending 200$ on aftermarket shocks. I highly recommend this if your on a tight budget like me. Thanks for reading.
First picture is compressed and extended front shocks and second picture is the rear shocks.
ashland82391 is offline
post #2 of 122 Old 04-09-2012, 01:33 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I know what goes into building a quality shock absorber.
Those shocks are on par for the price.
Joe Dillard is offline
post #3 of 122 Old 04-09-2012, 01:36 AM Thread Starter
ashland82391
Well, you gotta work with what you can afford.
post #4 of 122 Old 04-09-2012, 02:05 AM
Joe Dillard
Yep, I've been doing that for years & years.
I was raised by white trash in the '60's in Los Angeles, CA and know all too well what its like to be on a budget.
post #5 of 122 Old 04-09-2012, 04:37 AM
Louie4
I did the same thing and I knew what I was getting for the price. The shocks ride fine on the road for me but sometimes I feel they are too soft on the trail. I'm thinking we just put those shocks you mentioned on my Buddies CJ-7. He put Ford F250 shock towers on because his other ones just didn't have the travel. His is a trail rig and on the last ride he broke all but one shock mount so this was a big improvement.
If I can find a decent set of used Bilstein's I'll try to get them in the future though. Right now I need a new steering linkage.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 122 Old 04-09-2012, 07:04 AM Thread Starter
ashland82391
Yeah right now i just have them under my jeep with my 2in booms but this friday im starting my s10 bastard pack lift and hopefully I end up with about 4in total lift including the booms.
post #7 of 122 Old 04-15-2012, 08:03 PM
booboowv77
Great info! The only problem I see is when you flex it being all the shocks have 2 inch less compressed length it would limit your up travel when on uneven ground. Might not be that big of deal but just a thought. Do you have any pics of it flexing to see how it sucks up the down tire?
booboowv77 is offline
post #8 of 122 Old 04-15-2012, 09:10 PM
94chb
your doing a bastard pack on a sua setup.... ?????? and expect 4in lift??
94chb is offline
post #9 of 122 Old 04-15-2012, 10:32 PM
4x4JB
With 2" boom shackles. 4" total including shackle. Sounds right to me with sua. If he was SOA it would be crazy. 5.5 stock then add 2 for the booms and 2 for the bastard.... That's 9.5" lift if he was SOA. So not needed haha.
4x4JB is offline
post #10 of 122 Old 04-15-2012, 10:53 PM
dspar00a
Have any pictures with them mounted??
dspar00a is offline
post #11 of 122 Old 04-15-2012, 11:46 PM Thread Starter
ashland82391
no one ever said anything about a soa
post #12 of 122 Old 04-15-2012, 11:48 PM Thread Starter
ashland82391
the pictures above are of them mounted. i just finished the bastered pack so ill post more pictures up.
post #13 of 122 Old 04-16-2012, 12:03 AM
94chb
Neither did i
i did a bastard pack for a buddy and all it did was not allow the springs to sag like they were it was back to stock height.
94chb is offline
post #14 of 122 Old 04-16-2012, 05:06 AM Thread Starter
ashland82391
Neither did i
oh ok I got a little mixed up there, but yes now that the basterd pack is done im netting about 4 inches plus some in the back.
post #15 of 122 Old 04-17-2012, 02:35 PM Thread Starter
ashland82391
here you go
100_2041 (800x600).jpg   100_2044 (800x600).jpg   100_2043 (800x600).jpg   100_2042 (800x600).jpg
Thoughts about this lift?? Skyjacker 4" Economy Lift Kit with Hydro Shocks Enimo TJ Wrangler Technical Forum 31 03-05-2012 06:24 PM
will Rancho RS9000 (5-6in lift) shocks work with a Rough Country (4in lift) kit? Arron TJ Wrangler Technical Forum 1 04-02-2011 01:12 PM
best shocks for 4inch lift, 1 inch body lift epeck87 TJ Wrangler Technical Forum 0 04-05-2009 01:49 PM
jeep lift kit install on truck-u 76flh Wrangler General Discussion 19 11-17-2008 04:03 AM
2 inch lift - Shocks or no shocks?? BuzzHog JK Wrangler Technical Forum 5 03-25-2008 03:58 PM
