YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid - JeepForum.com
post #1 of 13 Old 11-02-2008, 05:28 PM Thread Starter
GMC7000
I have been having trouble shifting from 1st to 2nd etc...in 4wd
1)what type of transmission fluid should you use in a 93 YJ?
2) also trying to figure out if I have found the bolt for the fill hole, opposite the drain plug and takes a 15/16 wrench.......is this the right bolt?
3) the drain plug has a magnet, how much or how big is too big of a piece of metal to find? I am a little concerned because I found a small piece that is about 1/2" long
GMC7000 is offline
post #2 of 13 Old 11-02-2008, 07:38 PM
TSEJEEPERS
Picture of piece of metal? I use Penzoil Syncro mesh in my transmission.
My fill hole AX15 is on the same side of the drain hole. Higher up.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 13 Old 11-02-2008, 07:40 PM
BadAddetude
Pic of said piece of metal? 1/2 inch is good size for a transmission. Syncromesh is recommended here.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #4 of 13 Old 11-02-2008, 07:54 PM
TSEJEEPERS
What transmission? Like I said my AX 15 on a 93 YJ with a 4.0L is on the drivers side. The drain is down low and the fill is higher up.
post #5 of 13 Old 11-02-2008, 08:45 PM Thread Starter
GMC7000
GMC7000 is offline
post #6 of 13 Old 11-02-2008, 08:45 PM Thread Starter
GMC7000
GMC7000 is offline
post #7 of 13 Old 11-02-2008, 08:47 PM Thread Starter
GMC7000
GMC7000 is offline
post #8 of 13 Old 11-02-2008, 08:48 PM Thread Starter
GMC7000
yea this is from my 93 Wrangler manual transmission 4 litre
GMC7000 is offline
post #9 of 13 Old 11-02-2008, 08:54 PM Thread Starter
GMC7000
oh yea the penny did not come out of the transmission
GMC7000 is offline
post #10 of 13 Old 11-02-2008, 09:04 PM
yjcrawlr
Were you using mt90? Or your asking if you should use mt-90?
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #11 of 13 Old 11-02-2008, 09:15 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Joe Dillard is offline
post #12 of 13 Old 11-02-2008, 09:21 PM Thread Starter
GMC7000
asking if I should use mt 90
GMC7000 is offline
post #13 of 13 Old 11-04-2008, 07:11 PM
yjcrawlr
I use mt-90 now but I think I had less noise when I ran mobil one 5-30 synthetic. Dealer told me to run regular 10-30 motor oil. I had some 5-30 mobil one laying around in the shop so I tried it, the ax-15 was near silent. Now with mt-90 a little more noise. I think I will go back to mobil one next oil change.
yjcrawlr is offline
changing my transmission fluid Joezilla TJ Wrangler Technical Forum 17 02-11-2012 09:36 AM
Changing transmission fluid TexasToker TJ Wrangler Technical Forum 2 06-05-2009 11:12 AM
1/2" piece of metal in transmisson fluid drain plug GMC7000 TJ Wrangler Technical Forum 20 11-03-2008 10:15 PM
Changed my transmission fluid. Metal filings on the plug? TheMightyGoat TJ Wrangler Technical Forum 15 11-03-2007 07:22 AM
Changing Transmission Fluid dgugert TJ Wrangler Technical Forum 2 08-07-2007 12:03 PM
