YJ trans help needed - JeepForum.com
post #1 of 5 Old 09-27-2012, 08:35 PM Thread Starter
kinson137
I have a 95 YJ thats manual trans was falling apart, and I didnt have the money to fix, so I pulled an automatic out of the scrap yard to install. The manual held togather for a year but finaley quite. after trying to install the auto a few things went wrong: it was an 1" shorter in overall length and the transfer case bolts on but does not seal with the output shaft. Now I have this trans bolted up the the engine but I have no idea what trans it is, there are no plates or stampings. any way I can identify it so I can find a transfer case that DOES work with it?
kinson137 is offline
post #2 of 5 Old 09-28-2012, 08:28 AM
Jeepsr4me
You really need to give us more info on what you got the trans out of. Explain why the transfer case is not sealing? Does it seem like the shaft is too long and holding the cases apart?
Jeepsr4me is offline
post #3 of 5 Old 09-28-2012, 08:51 AM Thread Starter
kinson137
I thought I got it out of a YJ, I was under the impression that only YJs had the square headlights and the PRND selecter was on the colum (not the floor) but to be honest that's all I know about the jeep I pulled the trans out of. As far as it not sealing: the manual trans was recessed about an 1 1/4" and the transfer case stuck out the same amout. So they fit togather nicely. The new trans is recessed deeper around 2 1/2", so the transfer case goes in far enough (and bolts to trans) to make contact with the output shaft but not far enough to seal inside the trans (transfer case does not make is to output shaft seal) fluid is pouring right past output shat seal
post #4 of 5 Old 09-28-2012, 10:36 AM
jokerchief462
Pictures are needed and someone out here will help you identify the trans. Then you can work a solution.
jokerchief462 is offline
post #5 of 5 Old 09-28-2012, 11:47 AM
yj4trails
You prob have the 999 and when you switched from the 5speed your input shaft if the transfer case is to short. Get seal extension from Teraflex. Search forum. A few have gone to the auto. Good info in there.
94 YJ trail jeep...mine
03 TJ small lift n 33's hers
yj4trails is offline
help needed , trans , transmission , YJ
engine and trans replacement help needed Fonz3482 YJ Wrangler Technical Forum 0 09-15-2011 10:41 AM
YJ's with auto trans?... pic needed ghost183 YJ Wrangler Technical Forum 11 10-03-2008 09:27 AM
Magnet In Trans Pan, Needed In New Pan? cvd TJ Wrangler Technical Forum 4 09-21-2008 09:01 PM
Trans/Transfer case needed docneon TJ Wrangler Technical Forum 1 02-28-2008 07:33 AM
Trans Needed tensortrucks00 YJ Wrangler Technical Forum 2 03-07-2006 05:53 AM
