YJ tranny problem - JeepForum.com
post #1 of 8 Old 01-17-2013, 08:07 PM Thread Starter
Yellow1
YJ tranny problem
Hello, Im in need of a bit of help.
During a recent road trip, I noticed a high whine and a smell similar to burnt popcorn coming from my tranny. Its an ax5, and there is a leak. I took it to a shop to see if I could continue my trip home, and was told the trans gears are shot and I need a new tranny (but I would be able to go the last 150 miles). The only thing I noticed when I got home, aside from the smell and sound, is the difficulty in getting into reverse. The oil levels are extremely low, burnt, and black, and I feel that perhaps the tranny just needs oil and the shop just wanted to make a quick buck. I know its a long shot that anyone has an answer with such a vague description, but is it common for performance issues/ high pitch whines, when the oil levels are low? Im having a hard time finding this topic on the forum.
Thanks
Yellow1 is offline
post #2 of 8 Old 01-17-2013, 08:24 PM
bigbossd1030
Yes it is going to make some noise if the fluids are low. Drain out the tranny and run some 10w30 through it for a little bit. I'd say 100km or so. Then empty her out again and FIX the leak. And put in new oil. If it is better, then great.
I would swap for an ax15. But if cash flow is an issue then hope to hell the ax5 is going to hold up. The guy you want to chime in is max. He knows a thing or two about jeep trannys.
I think you will notice a difference with fresh fluid in there.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 8 Old 01-17-2013, 08:28 PM Thread Starter
Yellow1
Thank you, I'll do that tomorrow and see if there is an improvement.
Yellow1 is offline
post #4 of 8 Old 01-18-2013, 04:54 AM
Mark05059
whats it going to hurt to try it... if it doesnt work then you need a new trans... if it works you dont.. kinda a no brainer there... use 10w30 motor oil in it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 01-18-2013, 05:09 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
All sound advice so far.
If you ran low on transmission oil, you probably smoked the bearings. The excessive heat wouldn't have very kind to the gears either.
Where are you located?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 8 Old 01-18-2013, 12:16 PM
Siva283
I melted 2nd and 3rd in my ax5 a few weeks ago. If your gears are fine you can get rebuild kits for $100 at Autozone. I would be willing to bet at a minimum your bearings are toasted.
Ask me how I know...
Siva283 is offline
post #7 of 8 Old 01-18-2013, 12:24 PM Thread Starter
Yellow1
Max
I am in San Jose.
Yellow1 is offline
post #8 of 8 Old 01-18-2013, 03:01 PM Thread Starter
Yellow1
So I drained the gear oil- half a quart in the tranny. Im seriously confused as to how the shop failed to inform me of this. The pilot bearing seems to be shot, but the sound went away when I filled the tranny with 10w30. It runs a lot better, but getting into reverse was almost impossible. Had to floor the gas to get it to move.
Yellow1 is offline
