Yj trac bar removal ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj trac bar removal ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-06-2014, 10:17 PM   #1
drg1
On the front trac bar is the nut on the torx bolt welded or tanged to the frame? Or is it just a regular type nut
drg1 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 06:16 AM   #2
Old4X
1990 CJ7
Not welded. But it is a tight fit
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 07:09 AM   #3
ACs95YJ
If it's any consolation, I just lifted my 95 and it was the only bolt I didn't have to cut off. Soak it down with penetrating oil before you attack it.
Sent from AutoGuide.com Free App
95 YJ 2.5L AX-5, 4" Zone Springs, 1" BL, 5/8" Booms, Hercules 33-12.50's, Dodge Ram brake lines
ACs95YJ is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 07:31 AM   #4
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
Use an angle grinder with cut-off wheel. You know you want to use a new bolt if you decide to ever put it back.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 12:25 PM   #5
drg1
So with the angle grinder just cut the nut off and drive the bolt out ?
Unread 10-07-2014, 01:29 PM   #6
mike134
Only if you can't get the bolt out with a couple applications of PB blaster and a breaker bar. You want to be able to list it all on craigslist, just in case someone actually wants track bars (can't imagine why)
mike134 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 06:53 PM   #7
jason280
This is where a good set of impact rated Torx bits and a 1/2" impact really comes in handy.
jason280 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 08:18 PM   #8
langwilliams
the rear one I had to cut off, the front I cut the nut off the axle end an drove the bolt out, had to cut the bracket off the body mount end to get it off.
langwilliams is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 09:33 PM   #9
Mambo_Dave
Not sure if this will help, but skip to the one minute mark for the start of the underneath video
YJ Track Bar Removal (process and explanation of removal - most of it sped up)
https://www.youtube.com/watch?v=uMHc...5baoRIzLeFE_AQ
The front was easier than the rear.
Mambo_Dave is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 12:45 PM   #10
Mambo_Dave
Did you get it?
Unread 10-08-2014, 01:21 PM   #11
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
This is where trackbars and swaybars belong.
Swaybar/ Trac bar (noun) A Government mandated sissy bar to keep crybabies who would never own a utilitarian vehicle happy
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 06:04 PM   #12
bill8bud
bill8bud's Avatar
It is funny you say sway bars also. I have been running about 5 years without track bars. Best upgrade I did to the Jeep, price was right. The sway bar I pulled it about 2 years ago I got tired of fussing with the RE quick disconnects.
I am bored and dragged my sway bar out of the Jeep old parts pile and I am currently waiting for the paint to dry so I can reinstall it.
Throw the track bars away, I would advise hanging onto the sway bar you never know if you may want to run it again.
bill8bud is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 06:18 PM   #13
Tom95YJ
Tom95YJ's Avatar
Originally Posted by bill8bud
It is funny you say sway bars also. I have been running about 5 years without track bars. Best upgrade I did to the Jeep, price was right. The sway bar I pulled it about 2 years ago I got tired of fussing with the RE quick disconnects. I am bored and dragged my sway bar out of the Jeep old parts pile and I am currently waiting for the paint to dry so I can reinstall it. Throw the track bars away, I would advise hanging onto the sway bar you never know if you may want to run it again.
Only swaybar I would run is a antirock
Unread 10-08-2014, 06:19 PM   #14
Luuca
Professional Novice
Luuca's Avatar
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club Club #91
05 LJ Rubi "Ghost" 4.0L Auto NV241 D44/44 locked 4" RE Lift 1" BL 33s
Luuca is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 06:36 PM   #15
bill8bud
bill8bud's Avatar
I am not running it off road that is what the discos are for. I do have 3 other people in my house that drive my Jeep and my daughter who is 18 asked me to help make the Jeep a little more civilized when she does drive it.
She wins I am putting it back on for her.
