YJ Torque Specifications - Page 4 - JeepForum.com
post #46 of 60 Old 04-01-2012, 09:39 AM
BigDeaner
1987 YJ Wrangler
Originally Posted by J-Quad View Post
BigDeaner,
100 ft/#s is WAY tighter than it needs to be for YJ ball joints.
I just snug them up and then continue to tighten the nut (~20*) to the next castle nut slot.
Think about it -- why would they be outfitted with castle nuts if they were to be tightened THAT tight?
J-Quad
That could definetly explain why my cotterpin is just missing the castle nut, and the stiffness in turning the knuckle. But why the frick does the manual state 100 ft/lbs, can anybody else back him up on this. I like using the torque wrench, feel more confident that things are exactly where they should be. I looked, and looked all day and night and found everything from 70-100 ft lbs, which is a big difference. There's gotta be a factory torque value listed for this somewhere, I cant be the first guy here to replace his balljoints on a jeep yj, lol.
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
BigDeaner is offline
post #47 of 60 Old 04-01-2012, 10:32 AM
J-Quad
35 Ft-Lbs
420 In-Lbs
47.45 N-m
Connects: Tie Rod End To Steering Knuckle
Years: 1987-1995 Vote Record: Vote
Note: YJ - Tie Rod End to Steering Knuckle Nut
Info Source: http://www.torkspec.com/torkspecmm.aspx?KI=278
-- Listed about 3/4 of the way down the page...
J-Quad
-- '95 YJ, 4-cyl, 5-speed.
From Dec-Mar, it wears an 80" snowplow. From Apr-Nov, it gets muddy on the 2-tracks!
"War does not determine who is right, war determines who is left."
J-Quad is offline
post #48 of 60 Old 04-01-2012, 11:15 AM
BigDeaner
1987 YJ Wrangler
35 Ft-Lbs
420 In-Lbs
47.45 N-m
J-Quad
Found the same webpage in my searches last night, and unfortunatlty thats not what I'm referring to The balljoints are not the same as the tierod ends, and the torque value would be completly different, thank you for the suggestion, but i dont think were on the same page anymore. UPPER/LOWER ballstuds/balljoints is what I'm after, not the tie rod ends. I cant even use the specs for my tierod ends anyways, as I'm running 1 ton chevy rod ends now
1987 JEEP YJ LAREDO
NP231,AX15,D30,D35
post #49 of 60 Old 04-01-2012, 11:32 AM
BigDeaner
1987 YJ Wrangler
100 Ft-Lbs
1200 In-Lbs
135.58 N-m
Connects: Steering Knuckle To Axle Assembly
Note: YJ - Steering Knuckle to Axle Balljoint Stud Nut
This is what I'm needing the torque value for, and even this website lists the torque at 100 ft/lbs!
1987 JEEP YJ LAREDO
NP231,AX15,D30,D35
post #50 of 60 Old 05-07-2012, 03:52 PM
el scorcho
Doesn't look like they left much out.
Offroad-Review.com Jeep Wrangler YJ Torque Specifications
el scorcho is offline
post #51 of 60 Old 05-01-2013, 11:42 AM
Oper8or
My question: why isnt this a sticky?
Oper8or is offline
post #52 of 60 Old 05-01-2013, 04:48 PM
NonRubicon
It is a sticky: YJ Frequently Asked Questions (FAQ), Write Ups & stock specs. Look here first
It can be found in the third link from the top.
Someone just revived a sleeping thread that was last posted to in 2010.
NonRubicon is offline
post #53 of 60 Old 05-01-2013, 05:53 PM
5-90
5-90's Avatar
1988 XJ Cherokee
www.kelleyswip.com/tech.html. As I collect FSMs, I'm trying to pull specs from them and get them up on the site.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #54 of 60 Old 05-02-2013, 12:12 AM
YJrock88
Awesome, thank you for posting
YJrock88 is offline
post #55 of 60 Old 07-01-2013, 12:11 PM
Scorch1969
Originally Posted by Brandon_YJ View Post
50 ft-lbs for the larger mounts
35 ft-lbs for the smaller ones
Nice, i never did find those specs when i put in new poly bushings and 2" body lift, think i better go check what i torqued them to, thanx
Scorch1969 is offline
post #56 of 60 Old 08-07-2013, 06:42 PM
caoboy
Bumping this, does anybody know the torque spec for the transmission mount->transmission?
*edit*
I think it is this :
Rear Support-to-Crossmember Bolt 45 Nm (33 ft-lbs)
caoboy is offline
post #57 of 60 Old 12-08-2015, 01:09 PM
Chay
How do I know which order to torque the rocker arms on a 4.0
Chay is offline
post #58 of 60 Old 12-08-2015, 02:06 PM
LenVino
*edit*
I believe that depends on what mount and hardware you have. If you have lock rings that came with the mount you can just hand tighten really snug and you should be ok. Same goes for nylock nuts..
Also, don't forget the anti-seize..
LenVino is online now
post #59 of 60 Old 12-08-2015, 07:35 PM
fishadventure
Originally Posted by LenVino
I believe that depends on what mount and hardware you have. If you have lock rings that came with the mount you can just hand tighten really snug and you should be ok. Same goes for nylock nuts.. Also, don't forget the anti-seize..
2013 question. The 2015 question was rocker arms.
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #60 of 60 Old 12-08-2015, 07:45 PM
Rwrangler
Rwrangler's Avatar
Brandon_YJ,
Great job. Thanks. I was wondering if you have the body mount bolt torque specification on a 1991 Jeep Wrangler Renegade, 6 cyl, hard top
Rwrangler is offline
specifications losfreddy TJ Wrangler Technical Forum 6 09-20-2015 03:43 PM
JK Stock Specifications needmorehp JK Wrangler Technical Forum 1 09-05-2009 08:30 PM
I6 4.0 specifications toberste TJ Wrangler Technical Forum 4 04-11-2009 10:06 PM
Spring specifications BASHOdi TJ Wrangler Technical Forum 0 02-14-2008 03:49 PM
FAQ - Dana 30, 35, and 44 specifications Wheelin98TJ TJ Wrangler Technical Forum 2 01-25-2007 02:47 PM
