YJ Torque Specifications - Page 2 - JeepForum.com
post #16 of 60 Old 11-14-2008, 07:39 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Originally Posted by BigDeaner View Post
I've been trying to figure out the torque specs for the body bolts. I just bought a daystar kit, and can;t find anything in the manual on what to torque them to.
50 ft-lbs for the larger mounts
35 ft-lbs for the smaller ones
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #17 of 60 Old 11-14-2008, 07:51 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by Ratmeat View Post
Good one for the sticky topics somewhere, IMO
It is, and has been, on the first page of the FAQ.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #18 of 60 Old 11-14-2008, 02:31 PM
TSEJEEPERS
Thanks Brandon
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #19 of 60 Old 11-14-2008, 10:09 PM
BigDeaner
1987 YJ Wrangler
where did you find those from?
BigDeaner is offline
post #20 of 60 Old 11-14-2008, 10:10 PM
BigDeaner
1987 YJ Wrangler
I'm not the smartest but i looked around and still could'nt find what u were talking about.
post #21 of 60 Old 11-15-2008, 07:04 AM
Alfons
Here are some pictures for those that don't have bolt sequence diagrams for the head & manifold installations. Some notes to go along with the pictures:
  • There's one head bolt on each engine that goes into the water cavity, these are the ones identified as needing Locktight to seal them properly.
  • The dowels refered to in the the 2.5 head installation can be a couple of spare head bolts used for head alignment, or you can make the dowels by using a couple of bolts the same size with the heads cut off and a slot cut into the tops for removal with a screwdriver. You put these dowels into holes #8 and 10, slide the head over the dowels, and then you can carry on with the rest of the instructions.
  • Run a tap through all bolt holes to clean them out and run a die over the bolt threads, otherwise bolt tightness (torque) won't be correct.
Alfons is offline
post #22 of 60 Old 02-22-2009, 03:44 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Bump. For GREAT info.
Thomas
-1987 YJ
Tompatt is offline
post #23 of 60 Old 05-02-2009, 05:42 PM
eric411420
I'm bored, VERY bored. So I thought I'd crack open a repair manual and list all the torque specs in a thread so that they will be searchable for future use.
Not sure if this has been done before, if so - then I guess we have some redundancy.
So here we go. Below are all of the torque specs of all the bolts listed in my Haynes Manual for the 1987 - 2003 Jeep Wrangler.
Or course I'll leave out all the non-YJ specific ones.
I'll get what I can tonight, and then work on it more tomorrow night. And then I'll clean it up and catagorize it better after that. Right now I'm just wanting to get the information typed while I'm running a very long and boring job here tonight and have free time.
Tune-up Specific Items
Automatic Transmission:
Filter Screws 30RH and 32RH - 35 in-lbs
Filter Screws 42RLE - 45 in-lbs
Pan Bolts - 14 ft-lbs
Carburetor Mounting Nuts/Bolts - 14 ft-lbs
Throttle Body Mounting Nuts/Bolts - 14 ft-lbs
Transfer Case:
Drain/Fill Plug NP231 15-25 ft-lbs
Drain/Fill Plug NP241 14-25 ft-lbs
Manual Transmission:
Drain/Fill Plug AX-4/5 - 32.5 ft-lbs
Drain Fill Plug AX-1500 - 25 ft-lbs
Drain/Fill Plug NV3550 - 14-20 ft-lbs
Spark Plugs:
2.5L Engine - 27 ft-lbs
4.2L Engine - 27 ft-lbs
4.0L Engine - 27 ft-lbs
Oil Pan Drain Plug - 25 ft-lbs
Oxygen Sensor - 22 ft-lbs
Wheel Lug Nuts - 80-110 ft-lbs
Rear Diff Cover Bolts - 30 ft-lbs
Front Diff Cover Bolts - 30 ft-lbs
I just stumbled upon this and I just had to tell you that YOU RULE! Thanks a million for taking the time to do this!
When seconds count, the police are only minutes away.
eric411420 is offline
post #24 of 60 Old 12-12-2009, 09:07 PM
J-Quad
Originally Posted by ionakana View Post
I'm added a leaf to my spring pack and got to thinking after I took it apart, how tight do I need to tighten the center bolt of the spring now that I have it put back together with the new leaf?
Maybe this should be determined and added to this thread....?
J-Quad
-- '95 YJ, 4-cyl, 5-speed.
From Dec-Mar, it wears an 80" snowplow. From Apr-Nov, it gets muddy on the 2-tracks!
"War does not determine who is right, war determines who is left."
J-Quad is offline
post #25 of 60 Old 12-14-2009, 07:50 AM
Matt_vs_YJ
J-Quad
35 ft lbs when installing and 25-40 to check them.
Call me Matt. I have a YJ.
If you're in the Hampton Roads area of Virginia check out the Middle Peninsula Jeep Association
Matt_vs_YJ is offline
post #26 of 60 Old 01-17-2010, 06:16 PM
blue-monster
What about the 3" body lift how much should be tight?
blue-monster is offline
post #27 of 60 Old 02-26-2010, 07:02 PM
Mitchness
Alright, I got one. How about the bolts for the transfer case skid plate-to-frame? Can't seem to find it in the Haynes and can't find it on here.
Mitchness is offline
post #28 of 60 Old 02-26-2010, 08:27 PM
Matt_vs_YJ
30 ft lbs. according to the FSM
post #29 of 60 Old 02-26-2010, 08:36 PM
Mitchness
Thank you very much.
post #30 of 60 Old 04-29-2010, 05:10 PM
Nielsen17
AHHH saved my life, well actually probably just hours of hair pulling frustration, but thanks
And to think I used to drive a jetta...
Men and fish are alike. We both get into trouble whenever we open our mouths.
Nielsen17 is offline
specifications losfreddy TJ Wrangler Technical Forum 6 09-20-2015 03:43 PM
JK Stock Specifications needmorehp JK Wrangler Technical Forum 1 09-05-2009 08:30 PM
I6 4.0 specifications toberste TJ Wrangler Technical Forum 4 04-11-2009 10:06 PM
Spring specifications BASHOdi TJ Wrangler Technical Forum 0 02-14-2008 03:49 PM
FAQ - Dana 30, 35, and 44 specifications Wheelin98TJ TJ Wrangler Technical Forum 2 01-25-2007 02:47 PM
