-   -   YJ Torque Specifications (http://www.jeepforum.com/forum/f12/yj-torque-specifications-587412/)
Brandon_YJ 07-27-2008 10:25 PM
I'm bored, VERY bored. So I thought I'd crack open a repair manual and list all the torque specs in a thread so that they will be searchable for future use.
Not sure if this has been done before, if so - then I guess we have some redundancy. ;)
So here we go. Below are all of the torque specs of all the bolts listed in my Haynes Manual for the 1987 - 2003 Jeep Wrangler.
Or course I'll leave out all the non-YJ specific ones.
I'll get what I can tonight, and then work on it more tomorrow night. And then I'll clean it up and catagorize it better after that. Right now I'm just wanting to get the information typed while I'm running a very long and boring job here tonight and have free time. ;)
Tune-up Specific Items
Automatic Transmission:
Filter Screws 30RH and 32RH - 35 in-lbs
Filter Screws 42RLE - 45 in-lbs
Pan Bolts - 14 ft-lbs
Carburetor Mounting Nuts/Bolts - 14 ft-lbs
Throttle Body Mounting Nuts/Bolts - 14 ft-lbs
Transfer Case:
Drain/Fill Plug NP231 15-25 ft-lbs
Drain/Fill Plug NP241 14-25 ft-lbs
Manual Transmission:
Drain/Fill Plug AX-4/5 - 32.5 ft-lbs
Drain Fill Plug AX-1500 - 25 ft-lbs
Drain/Fill Plug NV3550 - 14-20 ft-lbs
Spark Plugs:
2.5L Engine - 27 ft-lbs
4.2L Engine - 27 ft-lbs
4.0L Engine - 27 ft-lbs
Oil Pan Drain Plug - 25 ft-lbs
Oxygen Sensor - 22 ft-lbs
Wheel Lug Nuts - 80-110 ft-lbs
Rear Diff Cover Bolts - 30 ft-lbs
Front Diff Cover Bolts - 30 ft-lbs
Brandon_YJ 07-27-2008 10:49 PM
2.5L Specific Information:
Camshaft Sprocket Bolt - 80 ft-lbs
Crankshaft Pulley-To-Vibration Damper Bolts - 20 ft-lbs
Cylinder Head Bolts (87&88) - 85 ft-lbs (Bolt 8 - 75 ft-lbs)
Cylinder Head Bolts (89+) - 110 ft-lbs (Bolt 8 - 100 ft-lbs)
Driveplate-To-Crankshaft Bolts - Step 1 - 40 ft-lbs
Driveplate-To-Crankshaft Bolts - Step 2 - 60 degrees more
Exhaust Manifold Nuts - 23 ft-lbs
Flywheel-To-Crankshaft Bolts - Step 1 - 50 ft-lbs
Flywheel-to-Crankshaft Bolts - Step 2 - 60 degrees more
Intake Manifold To Cylindar Head Bolts - 23 ft-lbs
Main bearing caps in 3 stages: 40-70-80 ft pounds.
Oil Pan Mounting Bolts 1/4 x 20 - 7 ft-lbs
Oil Pan Mounting Bolts 5/16 x 8 - 11 ft-lbs
Oil Pump Bolts Short - 10 ft-lbs
Oil Pump Bolts Long - 17 ft-lbs
Rocker Arm Capscrews - 19 ft-lbs
Valve Cover Bolts With RTV - 55 in-lbs
Valve Cover Bolts With Pre-Cured Gasket - 44 in-lbs
Timing Chain Tensioner-To-Block Bolt - 14 ft-lbs
Timing Chain Cover-To-Block Bolts 5 ft-lbs
Timing Chain Cover-To-Block Nuts - 16 ft-lbs
Vibration Damper Bolt (Lubricated) - 80 ft-lbs
I6 (4.0L and 4.2L) Specific Information
Camshaft Sprocket Bolt - 50 ft-lbs
Cylinder Head Bolts 4.2L - 85 ft-lbs
Cylinder Head Bolts 4.0L - Step 1 - 22 ft-lbs
Cylinder Head Bolts 4.0L - Step 2 - 45 ft-lbs
Cylinder Head Bolts 4.0L - Step 3 - 45 ft-lbs
Cylinder Head Bolts 4.0L - Step 4 - Bolt #11 to 100 ft-lbs
Cylinder Head Bolts 4.0L - Step 5 - Other bolts to 110 ft-lbs
Flywheel/Driveplate bolts - 105 ft-lbs
Oil Pan Mounting Bolts 1/4 x 20 - 84 in-lbs
Oil Pan Mounting Bolts 5/16 x 18 - 132 in-lbs
Oil Pump Mounting Bolt Short - 120 in-lbs
Oil Pump Mounting Bolt Long - 17 ft-lbs
Rear Main Bearing Cap Bolts - 80 ft-lbs
Rocker Arm Bolts - 19 ft-lbs
Tensioner Bracket-To-Block Bolts - 14 ft-lbs
Timing Chain Cover-To-Block Bolts - 60 in-lbs
Timing Chain Cover-To-Block Studs - 16 ft-lbs
Valve Cover Bolts With RTV - 28 in-lbs
Valve Cover With Permanent Gasket - 55 in-lbs
Vibration Damper Center Bolt (Lubricated) - 80 ft-lbs
Intake and Exhaust Manifold Retaining Bolts/Nuts 1989 Only
Nos. 1 and 2 - 30 ft-lbs
Nos. 3 through 12 - 23 ft lbs
Intake and Exhaust Manifold Retain Bolts/Nuts All Others
Nos 1 through 5 and 8 through 11 - 23 ft-lbs
Nos 6 and 7 - 17 ft-lbs
more...
Brandon_YJ 07-27-2008 10:59 PM
General Information Common To All Engines
Balance Shaft Assembly Chain Cover - 105 in-lbs
Balance Shaft Assembly Carrier-To-Block Bolts - 40 ft-lbs
Balance Shaft Assembly Gear Cover Bolt/Stud - 105 in-lbs
Balance Shaft Assembly Sprocket Bolt - 250 in-lbs
Balance Shaft Assembly Tensioner Bolts - 105 in-lbs
Connecting Rod Cap Bolts - Step 1 - 20 ft-lbs
Connecting Rod Cap Bolts - Step 2 - 1/4 turn more
Main Bearing/Bedplate Bolts
Step 1 - Bolts 11, 17 and 20 - Hand tighten
Step 2 - Bolts 1 Through 10 - 30 ft-lbs
Step 3 - Bolts 1 Through 10 - 1/4 turn more
Step 4 - Bolts 1 Through 20 - 20 ft-lbs
Brandon_YJ 07-27-2008 11:25 PM
Cooling, Heating, and AC
2.5L Engine
Fan Clutch-To-Water Pump Bolts - 15-22 ft-lbs
Fan-To-Fan Clutch Nuts - 18 ft-lbs
Thermostat Housing Bolts - 13 ft-lbs
Water Pump Attaching Bolts - 13 ft-lbs
4.2L & 4.0L Engines
Fan Clutch-To-Water Pump Bolts - 18 ft-lbs
Water Pump Attaching Bolts - 9-18 ft-lbs
Fuel And Exhaust
Fuel Pump (Mechanical) Mounting Bolts - 13-19 ft-lbs
Carburetor-To-Intake Manifold Mounting Nuts - 13-19 ft-lbs
Throttle Body (TBI) Mounting Nuts - 16 ft-lbs
Throttle Body (MPI) Mounting Nuts - 108 in-lbs
Brandon_YJ 07-27-2008 11:39 PM
Manual Transmission
Clutch Housing-To-Engine Bolts 3/8" DIA Bolts - 27 ft-lbs
Clutch Housing-To-Engine Bolts 7/16" DIA Bolts - 43 ft-lbs
Clutch Housing-To-Engine Bolts M12 Bolts - 55 ft-lbs
Shift Lever Cover (Tower) Bolts AX 4/5, 15 - 13 ft-lbs
Shift Lever Cover (Tower) Bolts BA 10/5 - 17 ft=lbs
Shift Lever Cover (Tower) Bolts NV3550 - 75 in-lbs
Front Band Adjuster Screw With Adapter - 36 in-lbs
Front Band Adjuster Screw without Adapter - 72 in-lbs
Rear Band Adjuster Screw - 72 in-lbs
Bellhousing-To-Engine Bolts 10mm Bolts - 25 ft-lbs
Bellhousing-To-Engine Bolts 12mm Bolts - 42 ft-lbs
Beutral Start Switch - 24 ft-lbs
Torque Converter-To-Driveplate Bolts - 40 ft-lbs
Transfer Case
Transfer Case-to-Transmission Fasteners - 26 ft-lbs
Speedometer Cable Adapter/Sensor Clamp bolt - 90-110 in-lbs
Speed Sensor-To-Adapter Retaining Screw - 15-27 in-lbs
Clutch And Drivetrain
Clutch Master cylinder Nuts Or Bolts
1987-1995 - 19 ft-lbs
1996 - 26 ft-lbs
Pressure-Plate-To-flywheel Bolts
2.5L - 23 ft-lbs
4.2L & 4.0L - 40 ft-lbs
Driveshaft U-Join Strap Bolts - 14 ft-lbs
Front Differential Pinion shaft Nut - 210 ft/lbs
Rear Axle Pinion Shaft Lock Bolt - 14 ft-lbs
Front Axle Shift Motor Housing Bolt2 - 108 in-lbs
Front Axleshaft Hub Nut - 175 ft-lbs
Front Hub Assembly-To-Steering Knuckle Bolts - 75 ft-lbs
Brake Backing Plate Nuts - 32 ft-lbs
Rear Axle U-Bolt Nuts - 44-59 ft-lbs
Brandon_YJ 07-27-2008 11:43 PM
Brakes
Power Brake Booster Pushrod Inner Nuts (pre 1991) - 25 ft-lbs
Power Brake Booster Pushrod Outer Nuts (pre 1991) - 75 in-lbs
Power Brake Booster Mounting Nuts - 25-29 ft-lbs
Master Cylinder Mounting Nuts - 15 ft-lbs
Caliper Mounting Pins (1987 - 1989) - 25-35 ft-lbs
Caliper Mounting Pins (1990 And Later) - 132 in-lbs
Wheel Cylinder Mounting Bolts - 84 in-lbs
Wheel Speed Sensor Mounting Bolt - 90 in-lbs
Plenty more to come, suspension and steering is next.
I just need a break now.
The soreness in my hands is reminiscent of my younger days when I first discovered pornography. :thumbsup:
Brandon_YJ 07-28-2008 12:24 AM
Suspension And Steering
Leaf Spring Eye-To-Shackle Bolt Nuts - 95 ft-lbs
Leaf Spring Eye-To-Frame Bracket Bolt Nuts - 105 ft-lbs
Leaf Spring Tie Plate U-Bolt Nuts (Front) - 90 ft-lbs
Leaf Spring Tie Plate U-Bolt Nuts (Rear) - 90 ft-lbs
Shock Absorber Upper Nut (Front) - 45 ft-lbs
Shock Absorber Lower Eye Bolt Nut (Front) - 45 ft-lbs
Shock Absorber Nuts (Rear) - 125 ft-lbs
Stabilizer Bar-To-Link Bolt Nut - 45 ft-lbs
Stabilizer Bar-To-Frame Bracket Nuts - 30 ft-lbs
Stabilizer Bar Link-To-Tie Plate Nut - 45 ft-lbs
Track Bar
Axle Bracket Nut (Front) (1987-1993) - 74 ft-lbs
Axle Bracket Nut (Front) (1994) - 125 ft-lbs
Axle Bracket Nut (Front) (1995) - 105 ft-lbs
Frame Bracket Nut (Front) (1987-1994) - 125 ft-lbs
Frame Bracket Nut (Front) (1995) - 105 ft-lbs
Trackbar Nuts (Rear) - 125 ft-lbs
Steering Knuckle-To-Axle Balljoin Stud Nuts - 100 ft-lbs
Airbag Module Arming Screw (1995) - 10-15 in-lbs
Airbag Module-To-Steering Wheel Nuts (1995) - 100 in-lbs
Steering Wheel Nut - 25 ft-lbs
Intermediate Shaft Pinch Bolt Nuts - 33 ft-lbs
Steering Gear Mounting Bolts - 65 ft-lbs
Pitman Arm-ToPitman Arm Shaft Nut - 185 ft-lbs
Drag Link-To-Pitman Arm Nut - 60 ft-lbs
Drag Link Clmp Bolt Nuts - 36 ft-lbs
Drag Link-To-Tie Rod Nut - 35 ft-lbs
Steering Damper Lock Nut - 30 ft-lbs
Tie Rod-To-Steering Knuckle Nuts - 35 ft-lbs
Tie Rod Adjustment Sleeve Clamp Bolt Nut - 14 ft-lbs
Steering Damper-To-tie Rod Nut - 53 ft-lbs
Steering Damper-To-Axle Bracket Bolt - 55 ft-lbs
Brandon_YJ 07-28-2008 12:26 AM
Airbag Module Retaining Nuts (1995) - 100 in-lbs
Well folks, that looks to be it!
I'm going to go through the book and see if there is something I missed. If anyone wants to chime in and correct me or input something that I missed please do so.
Fernando 07-31-2008 05:06 PM
I was wondering about these values
Anyone has these on ft-lbs? I am not very good with numbers and my torque wrench comes with ft-lb or Nm graduations, not in-lbs
Thanks
BlackRhino 07-31-2008 07:09 PM
Thanks
...Just like you divide inches by 12 to get feet, e.g. 36 in./12 = 3 feet, take the in-lbs and divide by 12 to get ft-lbs. 84 in-lbs/12 = 7 ft-lbs. 123 in-lbs is 10.25 ft-lbs.
rgs112 08-09-2008 12:56 PM
Anyone know the spec for the bell housing to trans for an AX5? My Haynes does not list this spec (or it is not located in all of the logical places I checked.
Thanks.
Matt_vs_YJ 08-09-2008 04:28 PM
Thanks.
My FSM lists 28 ft-lbs for the bellhousing to engine bolts, and 27 ft-lbs for the bellhousing to transmission bolts.
BigDeaner 11-14-2008 12:34 AM
I've been trying to figure out the torque specs for the body bolts. I just bought a daystar kit, and can;t find anything in the manual on what to torque them to.
Ratmeat 11-14-2008 06:39 AM
Good one for the sticky topics somewhere, IMO
TSEJEEPERS 11-14-2008 06:44 AM
Me too I just got done installing mine and could not find any torque specs.
The time now is 09:59 AM.
