yj on tj frame - JeepForum.com
post #1 of 23 Old 02-25-2014, 07:42 PM Thread Starter
blackyj80
1987 YJ Wrangler
yj on tj frame
I have just came across a tj frame with axles and full power train. I need axles for my yj and have some rust on my frame. Does any one know how much work will be to put my yj body on a tj frame.
blackyj80 is offline
post #2 of 23 Old 02-25-2014, 07:43 PM
superj
Try it out. You could find the new cool mod
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 23 Old 02-25-2014, 08:00 PM
baktie_91YJ
If you can weld, easy, you just need to move the body mounts. I think there may be a difference on the height where the grill mounts, but don't quote me.
baktie_91YJ is offline
post #4 of 23 Old 02-26-2014, 04:47 AM
superj
thats how the cj are too. you have to put a spacer under the cj grill to use it on a yj
superj is offline
post #5 of 23 Old 02-26-2014, 05:24 AM Thread Starter
blackyj80
1987 YJ Wrangler
I can weld and have a lift and a welder. My biggest thing is will the body sit on the frame with out having to modify the frame it self. I dont mind moving body mounts. I have already done that with my 02 superduity chassis when I put an older body on it. I just like to find out as much as i can about doing something before I jump on a project. I can make life much easer than figuring it out as you go. I have found another set of axles out of a 89 yj for $250 that Im going to get today. I am still going to get the other jeep frame this weekend and going to keep digging on how hard it will be to change.
post #6 of 23 Old 02-26-2014, 06:51 AM
RH31379
1983 CJ7
Not sure how it'll work without having to modify the frame.. The TJ frame curves up above the rear axle and the body sits along side it. I don't know how the YJ body would work at that location
besides the 83 cj-7, also have an 87 yj, 6cyl., 5spd, weber upgrade, 6.5' western uni mount plow, also a 2000 Sahara, 4.0, 5 spd
RH31379 is offline
post #7 of 23 Old 02-26-2014, 08:58 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Didn't LilViper use a TJ frame? He did a ton of fabrication since he stretched it to LJ length though. I'm too lazy to look up his build thread right now.
Randonexplosion is offline
post #8 of 23 Old 02-26-2014, 11:51 AM
baktie_91YJ
The frame itself will work without major fab. It requires new body mounts, radiator mounts,and from what I've seen you may need to massage the body in the rear wheel wells and the front fenders. Shouldn't be terribly difficult if you have the fab skills
post #9 of 23 Old 02-26-2014, 04:59 PM Thread Starter
blackyj80
1987 YJ Wrangler
Thanks for all the info. I think Im going keep mine like it is for now and look into changing it a little bit more. maybe find another body and try it with that one.
post #10 of 23 Old 02-26-2014, 07:03 PM
panaceabeachbum
just curious what was the asking price on the rolling chassis
panaceabeachbum is offline
post #11 of 23 Old 02-27-2014, 07:32 PM Thread Starter
blackyj80
1987 YJ Wrangler
$400 it belongs to a friend of a friend.
post #12 of 23 Old 03-04-2014, 05:24 AM Thread Starter
blackyj80
1987 YJ Wrangler
Trans swap
Will the trans out of a tj work in a 87 yj. Both have 4 bangers with stick shift. reason for asking I can get engine and trans out of a tj for free.
Remember. . . .A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including my life.
post #13 of 23 Old 03-04-2014, 05:27 AM
flcracker
when I needed a new trans, I swapped one from a 2002 into my 92 to get the external slave....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #14 of 23 Old 03-04-2014, 05:38 AM Thread Starter
blackyj80
1987 YJ Wrangler
Did every thing bolt right up?
Did you use a clutch for a 02 tj or 92 yj
post #15 of 23 Old 03-04-2014, 08:01 AM
flcracker
Best I remember, I used a Luk repset for a yj with external slave and the slave/line/master prebled hydraulics for external yj also.... bolted right up
