YJ Tire/wheel question - JeepForum.com
post #1 of 3 Old 02-05-2013, 07:24 AM Thread Starter
mandorider
Im looking on craigslist for a set of wheels/Tires for my Jeep. 94 YJ.
My current tires are 225/75/R15
First question is... What is the range of tires I can put on the Rim (which is stock)
Second question is... if people are selling wheels with tires on them (which I see quit a bit of) How big of a wheel can I put on my Non-lifted YJ without any concerns? (assuming the bolt pattern, hub center bore and lug size are all the same) Because I see people selling 16s,17s,18s etc and am just trying to figure out if its ok to use or not because it will open up more possibilities for me.
mandorider is offline
post #2 of 3 Old 02-05-2013, 08:20 AM
StanF
30x9.5x15 is about the largest stock fit
235/75-15 is about 29" x 9.3", and is another good choice - typically much cheaper than 30x9.5.
StanF is offline
post #3 of 3 Old 02-05-2013, 09:53 AM
Beachcruiser
1987 YJ Wrangler
15" has a much wider selection of tires, that are less expensive than the other rim sizes.
7" wide rims will take 10.5 tires easily...most people like an 8" rim to go 12.5 wide. Backspacing is critical on those, tho.
31's will fit on a street duty stock YJ if you trim your flares a bit. They rub slightly when turning very sharply, but you can reset your steering stops to avoid that.
Off road, you can run 31s if you go to TJ flares/1" body lift & trim a bit of metal exposed by the new flares....
probably out breaking stuff.
Beachcruiser is offline
