Quantcast YJ tilts a bit to Driver's side - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ tilts a bit to Driver's side
Old 08-31-2007, 02:51 PM   #1
Alheim
.. and this is on a 2" BDS lift. The tilt is very small, a couple of degrees at most, but if you look from the front or rear carefully you can see the tilt.
Any ideas why it would sit like this? I was thinking maybe the body bushings are worn more on the driver's side (it has 195,000 miles after all). But besides that, everything is (or should be) uniform, with matching shocks/springs/bushings, etc.
Thanks in advance,
Alheim
'95 YJ 123bhp 4-banger powerhouse, 212,000mi
Alheim is offline   Reply With Quote
Old 08-31-2007, 08:57 PM   #2
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
My YJ does the same thing, I refer to it as my gangsta' lean.
http://www.4x4grace.com
"Beat it like it owes you money"
Jeep Wrangler with some bolt-on "stuff"
Hokie_YJ is offline   Reply With Quote
Old 08-31-2007, 09:30 PM   #3
jeepin1995
jeepin1995's Avatar
i'd leave it and not worry about..... cuz before long it'll be leaning towards the passenger side..... all YJ's do....
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 08-31-2007, 11:25 PM   #4
dukegnarley
are you saying that YJ ownership leads to fat girl friends?
Unlimited Length YJ "Sasquatch"
Build Thread
Renix 4.0
AW4 swap with awshifter = DONE
custom console
flatdash
dukegnarley is offline   Reply With Quote
Old 08-31-2007, 11:41 PM   #5
YJ_Aaron
Mine was showing about 3/8" of lean to pass side. Turned out the busing in my shackle on the frame on pass side was worn completely through.
Problem fixed and as of tonight seems tob level.
91 YJ rebuild! Rush to get it driving/wheeling.
http://ozarksjeepthing.com/c/index.php
YJ_Aaron is offline   Reply With Quote
Old 09-01-2007, 05:14 AM   #6
jeepin1995
jeepin1995's Avatar
UMMMMMMMMM no..... the rear passenger spring wears out faster because of the way everything twists under acceleration.....
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
350 in my YJ.....
http://www.jeepforum.com/forum/showthread.php?t=518364
build thread:
Old 09-01-2007, 09:40 AM   #7
Alheim
Ah damnit, so I'm destined to have a fat girlfriend if I continue to drive my YJ? Maybe I should trade in for a civic?
(p.s. - any other serious suggestions? lol)
Old 09-01-2007, 01:18 PM   #8
flame0086
How bad is the lean? pics would help. If it is really bad, check the part numbers on the spirngs, maybe even call BDS and see what they think about it.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 09-01-2007, 03:20 PM   #9
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
my jeep leaned too, except w. POS RC springs, call BDS, they got a lifetime warranty. but my lean was 2 or 3 inches lower on the driverside...probably WAY worse then yours, either way give BDS a call, they have awesome customer service.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline   Reply With Quote
Glock Forum
