YJ throwing codes 24 & 27 - JeepForum.com
post #1 of 6 Old 06-14-2013, 08:36 PM Thread Starter
jason280
Quick backstory on the Jeep, its a '94 6cyl/5 spd that I bought just over a year ago. Jeep had been severely neglected, and took a little TLC to get it running correct. Ended up putting in new plugs, fuel pressure regulator, fuel filter, and swapped out the IAC & TPS with used models from a 6 cylinder XJ. Ran great afterwards, and I believe the prime culprit in the original issues was the IAC and/or the TPS.
Jeep has run great since everything was corrected until the last week or so. Doesn't idle very well, and requires feathering of the throttle to crank. Seems to run pretty well under load and down the road, but idling is inconsistent. Ran the codes, and I'm getting the standard 12/33/55, but its also throwing "24" and "27". Odd thing is, it throws/repeats "27" twice in succession.
I know 24 is for the TPS, so I need to troubleshoot it and check the voltage. I'll probably just order a replacement off eBay, looks like you can pick them up delivered for under $20. I'm not so sure about 27, seems like it deals with either the injectors and fuel system.
Any suggestions on troubleshooting this particular code, and any guesses as to why it would pop up twice reading the codes?
jason280 is offline
post #2 of 6 Old 06-17-2013, 07:45 AM
Que89YJ
You deal with the devil you know. If you have an idle issue it might throw a second code because of it. The TPS is cheap and easy. Start with the TPS.
Que89YJ is offline
post #3 of 6 Old 06-17-2013, 12:23 PM
idaholtby
Normally with the erratic/stalling idle issues I would first suspect the IAC or clogged port for it on the throttle body, but with code #24, and that you have to feather the throttle, I agree with Que. With a new TPS, then clear your codes and see how she runs and what codes, if any, return. You can test your TPS first with a meter if you want to be sure, but code #24 is pretty telling. The TPS is a simple rheostat with 5volts on one side, Ground on the other and then the wiper feeds the positional voltage to the ECM. Any dead spots in resistance will show a voltage drop rather than a smooth change with throttle movement.
idaholtby is offline
post #4 of 6 Old 06-17-2013, 07:24 PM Thread Starter
jason280
I went ahead and ordered a replacement TPS off eBay, no reason to fight with the current one when I can get a replacement for $19 shipped. The symptoms I am having are similar to a '93 Sahara I bought a couple years back, and a replacement TPS solved its issues. Hopefully, this one will do the same.
jason280 is offline
post #5 of 6 Old 06-18-2013, 02:05 PM
idaholtby
Understood.... I would only suggest that if this replacement does not fix your issue, then reinstall the original before continuing with troubleshooting. It is easy to induce problems with replacement parts that then further complicates the troubleshooting process.
post #6 of 6 Old 06-18-2013, 03:59 PM
PA_YJ19
27 Can sumtimrs b a bad connection at the injector, or was for me. Look at all ur injectors an mess with the little clips on top, see if me r broken. Mine was broken and would only throw the code while offroading or after because it would wiggle itself loose. I cut it off and spliced in a new one with a little plastic lock on it. Haven't had ne troubles with that one since. Just an idea check them out n make sure all ur electrical connections r good on ur injectors.
PA_YJ19 is offline
