Yj tcase and axles - JeepForum.com
post #1 of 5 Old 08-28-2013, 06:54 PM Thread Starter
codyyj93
Yj tcase and axles
I'm doing a dana 60 rear axle and dana 44 front axle both out of a ford. Let's say I'm going to run a 4.10 or 4.56 gear ratio. Do I need to do anything with my np231 tcase or transmission besides new shafts and sye???
codyyj93 is offline
post #2 of 5 Old 08-28-2013, 08:00 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
You may want to cap-off the vacuum disco stuff coming from the tcase since you won't be using it anymore. You may want to swap in a different speedometer gear to help offset the different ratio & tire size you are going for.
Joe Dillard is offline
post #3 of 5 Old 08-28-2013, 08:22 PM Thread Starter
codyyj93
Awesome I have heard about the vacuum capping but the speedometer gear just adjusts so you can see how fast your going or am I way off?
codyyj93 is offline
post #4 of 5 Old 08-28-2013, 09:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll have to purhase a new speedometer gear or just use Kentucky windage based on a GPS reading. As for the vacuum capping, here's a little reading.
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Hope you don't mind that I moved your thread, I thought it would get more hits here.
Luck Favours The Prepared
Anticanman is offline
post #5 of 5 Old 08-28-2013, 10:09 PM Thread Starter
codyyj93
No problem thank you!
codyyj93 is offline
