YJ tailight conversion: US to European - JeepForum.com
post #1 of 4 Old 09-09-2013, 06:46 AM Thread Starter
Aship
Brought my 94 Wrangler to France with me and have to conform to Euro standards. I've bought the Euro tail-light clusters from Morris 4x4 with the wiring adaptor but cannot figure out where the adaptor fits or, assuming it doesn't, how to modify the US wiring (2 bulb multi purpose stoplight, light and indicator) to the Euro 3 bulb (separate indicator) cluster? I'm getting a little desperate to say the least!
Aship is offline
post #2 of 4 Old 09-09-2013, 07:37 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to YJ Forum.
The forum you posted in (JeepForum Announcements & Comments) is for help with and questions about the forum.
Wheelin98TJ is online now
post #3 of 4 Old 09-09-2013, 10:44 AM
Xpress
If I recall correctly, the American setup is a 3 wire setup, one for running, one for reverse, and one for brake/turn. The brake/turn is in the same wire, you will need to trace back through the harness and isolate the brake lamp wiring, and the turn signal wiring. Somewhere up under the dash they tie into each other. Otherwise, the brake lamp will always be the turn signal lamp.
All about that unibody life.
Xpress is offline
post #4 of 4 Old 09-09-2013, 12:30 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here you go;
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
