YJ suspensions - JeepForum.com
post #1 of 26 Old 01-04-2008, 06:07 PM Thread Starter
Obcean2
YJ suspensions
So I took my YJ to the local Jeep place (not a dealer) to see if I got "took" or if I made a good deal. The guys seemed to think I did ok at 2500 for a 93 4.0 5 speed. One of the guys said "You know, of course, that your suspension is gone." Gotta say that no, I hadn't noticed. What a Noob. One of the fenders has a nice tire shaped cut out and I am only running 265s.
So of course I checked out the forum to see what I could learn about suspensions. I saw a couple of comments about YJ's not having coil springs. Gotta say I didn't notice that. I know that the YJ's have leaf springs, but I have seen lift kits with both.
So, after all that, here are my questions.
Do YJ's only have leaf springs? (I know I could go look but it is dark and cold at the moment.) Can you get a good lift with leaf springs? I have been looking at the Rancho 2 or 2.5 kits. I have read about leaf springs flattening out or inverting. Do leaf springs last as long as coil springs? Also, In order to maintain stability as I go up, should I get offsets for my wheels?
Finally, am I going to look like a total goober driving a lifted jeep with lil bitty 265's? (Can't do tires and suspension at the same time.
I know this was long, thanks for reading.
Obcean2 is offline
post #2 of 26 Old 01-04-2008, 06:19 PM
Petrucci
yes its all leaf springs, yes you can can a good lift, RE is very good, look here
www.rubiconexpress.com
also pro comp makes a good kit
www.explorerprocomp.com
Petrucci is offline
post #3 of 26 Old 01-04-2008, 07:11 PM Thread Starter
Obcean2
I just checked out Rubicon Express, the 4" lift is only around $31.00 more than the 2.5 lift, so I guess it would make sense to just get the 4. It just seems so......tall.
Obcean2 is offline
post #4 of 26 Old 01-04-2008, 07:37 PM
SonofSam02
you may want to do some reading in the faq section at the top of the forum
it will answer many of the questions that you have
SonofSam02 is offline
post #5 of 26 Old 01-04-2008, 08:05 PM
sam.b.
might wanna fill out your profile info while you at it
sam.b. is offline
post #6 of 26 Old 01-04-2008, 08:34 PM Thread Starter
Obcean2
um yeah, about the profile. It is as filled out as it can be. I don't know half the the stuff that is asked for.
I check the FAQ and I do a search before I ask questions.
Obcean2 is offline
post #7 of 26 Old 01-04-2008, 08:51 PM
hunkajunk
You will want to read up on slip yoke eliminators. As with a lift higher then 3" your drive-line angles may not be correct. The results of which range from bad to catastrophic.
Welcome!
Your wallet will never be the same again.
Edit: Go to Jeeps website and send your vin # to them and ask for a build sheet. That wil tell you what your Jeep left the factory with.
95 YJ 2.5 Low Output
hunkajunk is offline
post #8 of 26 Old 01-04-2008, 08:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Howdy be sure to say hi to my sister if you bump into her.
Although I'm one of the original folks who got Rancho off the ground way back when I'm not a fan of their kits for the YJ - never have been for several reasons.
Yep, leafs will sometimes sag or loose their original height or arch. That's normal and to be expected. However, leafs that are designed superior, will last alot longer, and provide a much smoother controlable ride when coupled to good shocks. It's a balancing act and lots of companies take too many shortcuts and their products simply ride & last accordingly.
Yep, there are a few kits out there that convert the leaf spring suspension from leafs to coil springs. There are also ways to convert to coilovers, which are much different and have the potential to be far superior than either of the other when done right....but.....$,$$$.
Coil conversion kits tend to take shortcuts in my opinion, and they don't come cheap either. Plus there's the factor of a complex install compared to simply tossing in a new set of leafs & shocks.
I'm not a big fan of wheel spacers although they do have their place. An alternative to that is wheels with a different offset which places the wheels out farther, and wider wheels to fit the larger & wider tires.
Joe Dillard is offline
post #9 of 26 Old 01-04-2008, 10:16 PM
Fogrunner
Fogrunner's Avatar
Hey, welcome. Don't worry aout lift and tires at the same time. Get the lift right and then get the tires as $$$ can afford.
Hey Joe, Thanks for the advice ( as always) I use wheel spacers and haven't had any trouble. I agree that correct backspacing is important, but spacers work till the money for the right wheels is available!!
'92 YJ 4 Cylinder, AX5, SOA w 39.5 x 13.5 x 16 Super Swamper IROK Radials's, D44/8.8 Moser Shafts, Homemade front and rear bumper, flat fenders and rock sliders.Lotsa $#@% Rust!!
Fogrunner is offline
post #10 of 26 Old 01-04-2008, 10:58 PM
provinT13
^^ doesn't that defeat the purpose of the lift? No matter how high you lift it, if you dont get bigger tires the axle is still at the same height, and it would look pretty funky, stock tires and a 4 inch lift.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #11 of 26 Old 01-04-2008, 11:49 PM
--chris--
--chris--'s Avatar
This is true if you plan on running 265's forever.
But if you cant afford both the lift and the rubber at the same time, then its ok to do it one at a time as money allows.
forgot to add:
http://www.jeepforum.com/forum/f12/how-will-my-jeep-look-xx-tires-x-x-lift-109455/
--chris-- is offline
post #12 of 26 Old 01-05-2008, 12:14 AM
goatboy
Naw, it doesn't necessarily make sense to go with 4" over 2.5"...you're on the right path, there...you get a lift based upon what you wanna do with your vehicle and based upon the size tires ya want... I coulda afforded a 4", but went with 2.5" for several reasons...my type of usage didn't predicate anything bigger than a 31" tire, so the 2.5" lift made sense...I didn't want to outrageously affect the center of gravity...I didn't want to do all the modifications necessary to support a 4" lift, although it did require a dropped pitman arm, normally not necessary for a 2.5" lift, but in my case, it became required.
So, pick your lift based upon how you will use your Jeep and the tires you want to install...
goatboy is offline
post #13 of 26 Old 01-05-2008, 10:06 AM
PanthrosRevenge
PanthrosRevenge's Avatar
The 2.5 kit comes with the nicer RE shocks, while the 4" kit comes with those cheap DT3000 shocks
'95 Wrangler
2.5L
Rear Aussie
31X10.5X15 Hitech AT's
2.5" Rubicon Express SD Lift
Midland CB w/ 4' Firestik II
PanthrosRevenge is offline
post #14 of 26 Old 01-05-2008, 10:26 AM
goatboy
Yep. If you prefer th 2.5" lift, go with it...
goatboy is offline
post #15 of 26 Old 01-05-2008, 10:37 AM
flysyj
flysyj's Avatar
ps..if you are looking at your front fenders..they are not 'flat' along the bottom edge, they all have a sort of 'simi circle' cut out in them..figure out what you want to do to your jeep, and then buy as you can afford..a 4" lift, will look great-if you are going with a 33" tire-eventually. it will also mean, new gears, sye and a few other things to work properly..go to car domain and look up yj's, they have thousands of pics of peoples jeeps and you can get an idea of the 'look and function' of what you want..welcome to 'yj-jeepin' empty your wallet and have some fun~fly
flysyj is offline
JK suspensions Blu-Jacket JK Wrangler Technical Forum 3 09-12-2009 01:17 PM
BDS suspensions Tim70 TJ Wrangler Technical Forum 27 10-06-2008 11:23 AM
Bds Suspensions & Wtf To Buy jbpdog TJ Wrangler Technical Forum 10 04-14-2006 12:35 PM
BDS Suspensions matty133 TJ Wrangler Technical Forum 4 03-07-2006 11:53 PM
RCD Suspensions Six Shooter YJ Wrangler Technical Forum 1 12-05-2003 06:22 AM
