yj suspension lift identification - JeepForum.com
post #1 of 16 Old 10-06-2013, 08:39 PM Thread Starter
Buschmann
1983 YJ Wrangler
Hey I bought a 1993 yj this year ..the PO told me he thought there was a 3.5" suspension lift and a 1" body lift but wast sure. Upon further inspection im not sure he was correct. The front has 6" shackles and the rear has 4" stock looking ones. The springs look different but it looks like the rubicon express 2.5" kit from what I can tell. The jeep has 33" bfg bajas on the front and its 24" to the rocker behind the front tire. The rear has 33" bfg mts and measures 24 1/4" in front of the rear tire rocker panel. My question is about the body lift...what size is the stock bushing and what would a 1" lift look like...srry for no pics yet..cant seem to size the resolution correctly
Buschmann is offline
post #2 of 16 Old 10-06-2013, 08:46 PM
nismo_2005
If it has a 1" bl on it there will be a 1" block between the stock bushing and the body. The blocks will most likely look like plastic. Unless it has a bl that replaces the whole bushing like the rough country 1" bl's do.
nismo_2005 is offline
post #3 of 16 Old 10-06-2013, 08:50 PM Thread Starter
Buschmann
1983 YJ Wrangler
How big are the stock bushings?
post #4 of 16 Old 10-06-2013, 08:53 PM
95YJMountie
95YJMountie's Avatar
If its a 1983, its not a yj. Just sayin.
Edit:
Just noticed the post says 1993. Your info says 1983.
95YJMountie is offline
post #5 of 16 Old 10-06-2013, 09:00 PM Thread Starter
Buschmann
1983 YJ Wrangler
Oh no..ill change that...1993 for sure
post #6 of 16 Old 10-06-2013, 09:01 PM
nismo_2005
Not sure off the top of my head but I will try and measure mine after I get ofd work tomorrow
post #7 of 16 Old 10-06-2013, 09:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Anticanman is offline
post #8 of 16 Old 10-06-2013, 09:25 PM
95YJMountie
Stock bushings are only an inch tall. You'll see the difference when you look. The body lift will be thinner and usually smooth black plastic looking material. The bushings will be rubber and if theyre stock, they will look old and dry rotted
post #9 of 16 Old 10-08-2013, 08:46 AM Thread Starter
Buschmann
1983 YJ Wrangler
Test
post #10 of 16 Old 10-08-2013, 09:31 AM Thread Starter
Buschmann
1983 YJ Wrangler
This is one of the side body mounts
post #11 of 16 Old 10-08-2013, 09:37 AM
SeanB95YJ
the rear shackle is definitely stock.... as are your body mount bushings.... there is no body lift, but there IS what looks to be a 1" transfer case drop
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #12 of 16 Old 10-08-2013, 10:11 AM
nismo_2005
The shackle angle and spring angle shows that it does have a spring lift
post #13 of 16 Old 10-08-2013, 10:40 AM Thread Starter
Buschmann
1983 YJ Wrangler
Thanks for the reply's guys...the next question was going to be about the tranny skid drop..here is the front shackle...im a little confused why I have lift shackle on front but not rear ...yet it sits level if not higher in the rear
post #14 of 16 Old 10-08-2013, 12:05 PM
nismo_2005
What is the eye to eye measurement on the front shackles? And if you have pics of the front and rear springs it looks like the rear springs have more arch to them.
post #15 of 16 Old 10-08-2013, 02:30 PM Thread Starter
Buschmann
1983 YJ Wrangler
Eye to eye they are 6" in front 4" in rear
