yj suspension flex - JeepForum.com
post #1 of 12 Old 08-23-2014, 05:08 PM Thread Starter
murdockyj46
yj suspension flex
Iv heard that yj's dont flex stock and i was wondering if it was true, and if possible someone could give me some ideas on how to get better articulation out of it.
murdockyj46 is offline
post #2 of 12 Old 08-23-2014, 05:38 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Take out the track bars and disconnect or remove the sway bar. Make sure the spring and shackle bushings are good, not age hardened. Make sure the bolts are not so tight you can't spin them with a wrench on the head.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 12 Old 08-23-2014, 07:00 PM
booboowv77
It's not stock, but does have stock springs. I think it works well!
https://www.dropbox.com/s/04ma02i70g...0hill.mp4?dl=0
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #4 of 12 Old 08-23-2014, 07:04 PM
Richard_
Spring over flexes better than spring under
Richard_ is offline
post #5 of 12 Old 08-24-2014, 03:23 AM
fratis
fratis's Avatar
depends entirely on the builder
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 12 Old 08-24-2014, 07:27 AM
Jeff Dodson
Probably don't flex as well as the COIL SPRING SUSPENSIONS.....
1988 Jeep Wrangler ( YJ )
2010Harley Davidson (EG)
1999 GMC Z71
Jeff Dodson is offline
post #7 of 12 Old 08-24-2014, 07:29 AM
Jeff Dodson
I guess I should have watched the video first.....
1999 GMC Z71
post #8 of 12 Old 08-24-2014, 09:48 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The stock springs are pretty flexy if you look in my build thread ( first few pages) you'll see how well a stock YJ flexes )
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 12 Old 08-24-2014, 10:20 AM
blitz134
The stock springs should flex well enough (especially with trackbar and sway bars removed), but you'll just have issues fitting larger tires without a lift. Short of going spring over, run a high quality spring (BDS, OME, etc) if you are going to lift it. And I wouldn't run anything over 3.5" of spring lift. The spring arch is increased to provide the lift which hurts its ability to flex.
Having a ton of articulation doesn't necessarily help you out in all situations, either. Running leafs is generally considered to be more stable in certain off camber situations. Yes, you are more likely to lift a tire in twisty sections, but as long as you have lockers, you'll continue to move forward.
Current Jeeps (Click to see build threads):
blitz134 is offline
post #10 of 12 Old 08-24-2014, 12:56 PM
jsawduste
2006 YJ Wrangler
Truth spoken here. Add ride quality to that statement also.
It`s a shame that most folks will never experience the ability of a well made leaf sprung vehicle. They can and do work very well.
jsawduste is offline
post #11 of 12 Old 08-24-2014, 07:40 PM
Mike Romain
Sway bar disconnect kits are the way to go for off road. Increases the flex a lot when disconnected and keeps it safe with good road manners when connected.
Mike
Mike Romain is offline
post #12 of 12 Old 08-24-2014, 07:57 PM
skizriz
1978 CJ7
A few buddies and I talking smack on the RTI ramp. They all had TJ's with long arm kits, and I have 4 old worn out YJ springs. They beat me, but not by much.
skizriz is offline
