YJ suspension - JeepForum.com
post #1 of 8 Old 08-31-2011, 07:30 PM Thread Starter
regan89
YJ suspension
I have a 93 wrangler with a 4 in suspension lift that the previous owner put on it and 33's. A problem I encounter while wheeling is that there is little to no articulation with the suspension. My next upgrade will me quick disconect swaybar links which should help a little, does anyone else have some tips that will help me with this problem?
regan89 is offline
post #2 of 8 Old 08-31-2011, 07:38 PM
zeus87gn
1987 YJ Wrangler
Remove the track bars
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #3 of 8 Old 08-31-2011, 07:44 PM
dillonjm
2013 WK
Pull off the sway bar and the track bars, they aren't needed on a leaf spring suspension. Then torque the shackles to around 45 ft/lbs (they don't need to be as tight as you may think).
Should help some. You may just have a cheaper set of springs that are stiff.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 8 Old 08-31-2011, 08:17 PM
rustybeater
i put castle nuts on my shackles and drilled some grade 8 bolts and used cotter pins.
rustybeater is offline
post #5 of 8 Old 09-01-2011, 07:57 AM
CopperHead_Road
Once you get your swaybar/tracbar removed. Check you shock and brake line lengths. Also read up on bump stops. Use the search feature, there is alot of good info here on both
CH_R
"My Poppa ran whiskey in a big-block Dodge, he bought it at an auction at the Mason's lodge"
CopperHead_Road is offline
post #6 of 8 Old 09-01-2011, 08:08 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Do all of this..... take it out 3 or 4 times then report back.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #7 of 8 Old 09-12-2011, 02:55 PM Thread Starter
regan89
alright thanks I'll have to try these suggestions
regan89 is offline
post #8 of 8 Old 09-12-2011, 03:37 PM
TheNewbie
Yep, get rid of the sway and trac bars and re torque the shackle bolts to 45 ft lbs.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Long Arm suspension...vs short arm suspension GMC7000 TJ Wrangler Technical Forum 105 11-09-2010 09:46 PM
Rubicon suspension vs. Islander/Mountain suspension GXP20T JK Wrangler Technical Forum 11 08-25-2010 08:54 PM
2" Suspension + 1" Body VS 3.5" Suspension tx_medic YJ Wrangler Technical Forum 13 06-17-2009 09:43 PM
OME 2.5'' suspension kit or Rancho 2.5'' Rockcrawler suspension kit? billabong266 TJ Wrangler Technical Forum 23 04-23-2009 02:05 PM
