yj stretch with xj leafs - JeepForum.com
post #1 of 12 Old 12-07-2015, 04:33 PM Thread Starter
rustybeater
Hello, I have searched and read a ton of posts on here about using xj springs to do a rear stretch on a YJ. I plan on using a fuel cell so I am not concerned with the axle hitting the tank and I am going to build or possibly buy a track bar. I already bought the way back hangers from ruff stuff and I am also swapping in a ford 8.8 while I am at it. I plan on going to SOA in the rear and for right now I am going to keep the front SUA for a little bit until I finish some other projects. In the front I have 4 in lift springs from rustys off road. I am trying to figure out what springs to go with to keep the jeep somewhat level and I was thinking about using stock xj springs because of the lift that I would gain going to SOA. I was trying to find out if people like this set up or is there another spring that would give better benefits or possibly more flex? Thanks for any help.
rustybeater is offline
post #2 of 12 Old 12-07-2015, 04:41 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Have you read through this thread? Lots of ideas.
http://www.jeepforum.com/forum/f12/r...ssion-1950961/
Randonexplosion is offline
post #3 of 12 Old 12-07-2015, 04:46 PM
fishadventure
Originally Posted by rustybeater
?...and I am going to build or possibly buy a track bar....
Alrighty then. You do that. But why???
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
post #4 of 12 Old 12-07-2015, 05:25 PM Thread Starter
rustybeater
I thought you needed it for anti wrap? Maybe I am wrong but that is why I am asking on a forum. Thanks for the link a lot of info. What did you end up doing?
post #5 of 12 Old 12-08-2015, 05:50 AM
calvynandhobbs
calvynandhobbs's Avatar
A track bar is for side to side movement for coil sprung vehicles. You need an anti-wrap bar like the one from MORE, RuffStuff, etc.
94 YJ - work in progress
calvynandhobbs is offline
post #6 of 12 Old 12-08-2015, 06:40 AM Thread Starter
rustybeater
http://www.ruffstuffspecialties.com/..._Code=Antiwrap. This is the link to what I wad looking at. You are correct anti wrap.
post #7 of 12 Old 12-08-2015, 08:28 AM
Randonexplosion
Deplorable
Just a difference in terminology. Traction bar, anti-wrap bar, ladder bar, track bar, panhard bar...
post #8 of 12 Old 12-08-2015, 09:03 AM
TSEJEEPERS
I would use stock XJ springs with a main leaf added.
How old are the front springs?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 12 Old 12-08-2015, 10:03 AM Thread Starter
rustybeater
The front springs are about 3 years old but, I don't belive that they have sagged too much
post #10 of 12 Old 12-08-2015, 10:17 AM
timatoe
timatoe's Avatar
I'm just starting mine, but am using essentially stock XJ springs all the way around (4-sets to make 2) each spring has two mains and two of the next longest spring then the rest of the stock pack.
timatoe is offline
post #11 of 12 Old 12-08-2015, 05:59 PM Thread Starter
rustybeater
Just out of curiosity are you using all brand new springs or are you getting them from a junk yard? I have not decided if I am going to try to stretch the front yet or not.
post #12 of 12 Old 12-08-2015, 11:11 PM
timatoe
timatoe's Avatar
Mine are all used, I didn't get any of them from a "junk yard" but it's no difference. I got one set that Norcal Chris used before linking his and the other set I got from two XJ's a guy had sitting in the yard of his shop.
timatoe is offline
