YJ Stereo Installation Help - JeepForum.com
post #1 of 4 Old 08-16-2010, 06:06 PM Thread Starter
bbbavaro
Hey guys, it's my first time posting here, and I'm wondering if anyone can help with some wiring problems I'm having with my stereo. I have two Boston Acoustics installed in roll bar boxes in the back, run with new speaker cables. But the front two speakers in the dash are not wired in. I reached up and found the wiring harness, but it seems like there are four wires coming out, I can't really tell. Anyways, should I use the existing harness and cables to wire the speakers into my head, or should I run new speaker cable? If I use the existing cables, what colors are they? Thanks!
bbbavaro is offline
post #2 of 4 Old 08-16-2010, 06:35 PM
HMFIC
When you say harness are you talking about the one where your head unit plugs in or where you speakers connect?
If your front speakers are the factory ones they are more then likely falling apart as the cones are made of a paper like material.
Either way just use factory wires for front. Better wires for speakers that small will not make any noticeable difference. If you cant figure out the wires just run new ones, its only 3 feet or so from head unit.
As to the colors I am not sure.
HMFIC is offline
post #3 of 4 Old 08-16-2010, 06:38 PM Thread Starter
bbbavaro
HMFIC--by harness i mean the one that connects the wire to the speaker itself. i'm hoping to get new speakers at some point, but the ones in their now are decent. should there just be two wires going from the speaker to the head unit?
bbbavaro is offline
post #4 of 4 Old 08-16-2010, 06:39 PM
OOXTEME
1991 Jeep Wrangler Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4″ x 6″
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Black/Red
Rear Speakers Size: 4″
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Originally Posted by ZeroGravity View Post
People really drive with the top down and the A/C on??
94 Yj 350 700R4 Swap with Ford 8.8 in progress, 3" BDS Lift, 1" Shackels, 3" Body, Rhino Lined Tub
OOXTEME is offline
speakers , YJ
Stereo Installation Black07 JK Wrangler Technical Forum 1 01-15-2007 03:23 PM
Installation of custom stereo Rocky529 TJ Wrangler Technical Forum 2 03-01-2005 12:52 PM
STEREO INSTALLATION beepbeep TJ Wrangler Technical Forum 6 07-16-2004 01:01 PM
Suggestions for Stereo sytem installation Beaveranger YJ Wrangler Technical Forum 9 03-14-2004 11:14 AM
Stereo Installation in Tuffy Console (help) graberc TJ Wrangler Technical Forum 3 07-09-2002 07:56 AM
