YJ steering linkage ? full size axles - JeepForum.com
post #1 of 4 Old 12-22-2001, 10:22 PM Thread Starter
Glassman
Need help with steering linkage for a YJ with fullsize blazer or cherokee axles. Column to gearbox any one done this before?
Glassman is offline
post #2 of 4 Old 12-22-2001, 10:54 PM
osburn
osburn's Avatar
Why not leave that part stock? Just change rod ends to match your existing pitman arm.
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 12-22-2001, 11:49 PM Thread Starter
Glassman
I came into a partly done project. They have the fullsize gearbox mounted on the outside of the frame. Column rod would run at an angle. Might be better of to go back to stock gearbox. Was looking for ideas. Thanks
Glassman is offline
post #4 of 4 Old 12-23-2001, 05:13 PM
Signman
Best thing to do would be to use some universal steering joints, one at the box and one at the top of the shaft. Use a new double D shaft as well. I did a steering conversion in my 57 Chev pickup and used Borgeson joints (borgeson.com)and a new shaft. shaft can be up to a 30 degree angle with no problems.
I used polished stainless but they sell steel as well...EXCELLENT construction and are all needle bearings, splined, smooth or double D.
Good luck
Cheers,
Ashley..
89 YJ built tough, NOT pretty
02 Liberty
I love my Country,
It's the Government I'm afraid of!
Signman is offline
full size axles with 3.50 gears? coldyj YJ Wrangler Technical Forum 15 10-15-2009 10:44 AM
Full size axles demoguru YJ Wrangler Technical Forum 3 02-10-2009 11:41 PM
full size axles Fastbeeatch YJ Wrangler Technical Forum 8 06-28-2008 04:19 PM
Full size axles.... 8dDUCE YJ Wrangler Technical Forum 12 07-24-2007 03:26 PM
V8 and 1-ton full size axles 95YJnh YJ Wrangler Technical Forum 16 04-15-2005 10:36 AM
