YJ Steering column/transmission help - JeepForum.com
post #1 of 1 Old 09-12-2010, 05:47 PM Thread Starter
Michaelgoesrawr
Michaelgoesrawr's Avatar
I've gotten my '88 up and running but my steering column plastic is starting to break and my turn signals don't work. What would be the best to do, find a new steering column or just fix the wiring and get a new signal set up?
My gears grind when I down shift, an ideas?
I'm new to this working on cars thing and I'd appreciate the help.
Michaelgoesrawr is offline
clutch , gears , transmission , turn signals , wiring
Will 00 TJ steering column interchange with 05 TJ column JWhip TJ Wrangler Technical Forum 11 07-23-2010 12:27 PM
do i really need a steering column? rmv42158 TJ Wrangler Technical Forum 6 06-17-2010 11:23 AM
Something in my steering column broke loose. I have no steering Swampwalker3 YJ Wrangler Technical Forum 5 11-06-2009 06:08 AM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 01:59 PM
