YJ steering column diagram - JeepForum.com
post #1 of 9 Old 11-07-2008, 03:45 PM Thread Starter
cavebiker
I just replaced the ignition switch on my '90 jeep wrangler YJ and am having a heck of a time getting everything put back together correctly. Does anyone have a diagram of the steering column? Thanks
cavebiker is offline
post #2 of 9 Old 11-07-2008, 04:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here's an old thread about the steering column that may help you some.
http://www.jeepforum.com/forum/showt...teering+column
And here is a link to a CJ steering column write-up (courtesy of rustywrangler) that make provide additional help.
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 9 Old 11-07-2008, 04:50 PM
ksm4_al
Maybe this will help.
ksm4_al is offline
post #4 of 9 Old 06-13-2009, 03:56 PM
DonAltman3
what do I need to do to make a tilt steering work with a non tilt steering column.
The black plug omn top of the column seems to fit just fine but the white or clear colored one doesn't want to go on.. I have an 81 jeep cj5 manual with 6cyl.
The tilt was purchased off ebay as a direct replacement but I think the top plug wiring is a little differn't
ARG!!!
DonAltman3 is offline
post #5 of 9 Old 06-13-2009, 06:48 PM
Mr YJ
I fitted a tilt column from a 91 YJ to a 92 YJ originally fitted with a non tilt column. I didn't need to do anything as it was a direct swap. What year is your replacement column from?
Originally Posted by Brian2o0o
If I can get my hands on my g/f's kayak I will try it...
92 YJ 2.5L 5sp manual trans. 4" lift with 33 X 12.50 Mickey Thompson Baja claws.
Rockhard cage, and SBC swap. Work in Progress
Mr YJ is offline
post #6 of 9 Old 06-14-2009, 01:36 PM
DonAltman3
I am not sure it is said to be a direct fit.. I got it from ebay.. one with the wrong bottom gear was sent and it would not accept the steering shaft.. so The seller asked me to ship both of them back... after spending 250 plus 20 shipping I spent another 35 to ship both back.. 40 days later still nothing.. after contacting everyone from ebay paypal and credit cards I was finally able to get some more information from the guy and contacted the local authorities... He kept feeding me a line about how his car broke down and he was down on his luck. I finally had enough and just a few days after I gave up on it I was shopping for another coumn when I ran across him selling both of the culumns I had sent back to him... this was enough for ebay to finally take some actuaion and the autorities contacted him... less then a week later I get this column... it looks as I remember the other one looking.. it bots up and fit perfectly.. however the top plug where the two wires go is the problem. The long electrically pin connector is correct. However the two on the top is off... the smaller plug (black) plugs in just fine.. it is the one away fromt steeringwheel on the top.. the one closer to the steering wheel will not plug in.. I took it off and noticed that some of the electrical pins on the cplomn didn't line up with the spade connectors inside the plug. My old jeep was an 81 cj5 non tilt.. I think this is one from a late 80's YJ. I imagine that the difference is shown on the diagrams above but I have never seen anyone not being able to just plug it in and ride. Needless to say I can't return this one I have to make it work somehow.
I am lost.
post #7 of 9 Old 06-19-2009, 04:38 PM
DonAltman3
I feel like a moron... once installed into the dash I couldn't get it to plug in becuase the plug have to go in a certain order.. the longer white one must be installed first.. then the black smaller one beside it.. if you try to do the black it wont work.. .. it is hard to figure out upside down under the dash.. I feel like a dope.
post #8 of 9 Old 07-14-2014, 02:12 PM
Ikeeg
I can't put it back together, it won't line up. What am I missing? (Steering column and steering wheel)
Ikeeg is offline
post #9 of 9 Old 02-14-2016, 08:04 PM
yellowoctupus
THANK YOU!!! For posting these pictures. I've been scratching my head for a day trying to figure out why my MJ ignition switch works backwards. I guess back in the day someone put in a 'tilt' switch instead of the 'non-tilt' they should have!!
yellowoctupus is offline
Steering column jeepmudgirl TJ Wrangler Technical Forum 4 04-13-2013 07:19 AM
Something in my steering column broke loose. I have no steering Swampwalker3 YJ Wrangler Technical Forum 5 11-06-2009 07:08 AM
90+ YJ steering column thenoblesock YJ Wrangler Technical Forum 5 09-16-2009 11:32 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-10-2009 12:20 AM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 02:59 PM
