YJ Steering Column in a CJ5 - JeepForum.com
post #1 of 1 Old 09-18-2012, 11:56 AM Thread Starter
FloridaCJ5
1976 CJ5
Hey Guys,
I have a 89 YJ tilt steering column I've installed into my 76 CJ5- the PO had installed a keyed ignition switch into the dash, cutting the plugs off the wiring harness to the ignition switch. Can ANYONE help me ID the ignition switch terminals on the switch so I can determine where the wires go ??? Thanks T.Mac
FloridaCJ5 is offline
Looking for a steering column for 89 wrangler, column shift!!! Where should I look? ChumSlam YJ Wrangler Technical Forum 1 09-15-2010 10:52 AM
Will 00 TJ steering column interchange with 05 TJ column JWhip TJ Wrangler Technical Forum 11 07-23-2010 01:27 PM
Something in my steering column broke loose. I have no steering Swampwalker3 YJ Wrangler Technical Forum 5 11-06-2009 07:08 AM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-10-2009 12:20 AM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 02:59 PM
