YJ steering box upgrade? - JeepForum.com
post #1 of 20 Old 04-27-2013, 06:03 AM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Going to look at a YJ this Sunday. He said the box is leaking and has a spare for it. I figured that if its going to be replaced is there a junk yard upgrade? Ie Durango box on TJs?
YJ specs TBI 350 Turbo 350 Dana 300 welded 12 bolt rear 44 front lock right. Comes with a 14b he already sold the Chevy 60 front. 5
36tsls on bead locks eventual plans would probably be tons and military 37s since I already have 16.5 8 lug wheels and drive it.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 20 Old 04-27-2013, 06:11 AM
Louie4
I'd heard the Durango box makes for easier turning but I have also heard that you lose some turning radius. That's what I've heard but I have not done the swap so I think it's best someone who has tell you their experience. I've gone back and forth with swapping out mine for a Durango box.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 20 Old 04-27-2013, 08:19 AM
skyj
I'm curious of this as well mine recently started to get loose. I tightened it up a bit and its still getting loose. I have already lost a bit of turning radius from the ranger pitman arm so I don't want to to lose more. Sorry to hijack OP. I have noticed Jk boxes are becoming popular, but don't know if its an upgrade
( they require lots fab'n to fit).
build thread:
skyj is offline
post #4 of 20 Old 04-27-2013, 02:37 PM
PA_YJ19
Durango box works fine for me, no noticeable loss in turning radius. The box itself is larger so it sits mayb a 1/4 farther to the right, by further I mean the pitman arm location is farther right from the frame than the stock box. What a did after I centered my wheel and tested my turning lock to lock was lengthen the draglink slightly to give me that 1/4 inch back I lost. This makes the wheel look slightly cocked to the right but I get full turn lock to lock no problem and it still drives straight as an arrow, the Durango box is much easier to turn with my larger tires than the stock box and it jumps back quicker in sticky situations. I tried boxes off of xjs, Dakota's, astro, and another yj on before deciding on the Durango one. None of the other ones turned the larger tires offroad worth a darn when I'm locked front and rear. My pump will whine a little when locked in 4lo in a tight turn but no complaints from the Durango box. If nething now I would like to find a larger PS pump that would fit. PSC makes one but I'm not paying an arm and a leg for a dang ps pump. I'm gona find one that fits from a JY eventually and is larger.
PA_YJ19 is offline
post #5 of 20 Old 04-27-2013, 02:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
When you find it, let me know. Boring it out a little is supposed to work but I haven't tried it yet.
http://www.virtualjeepclub.com/showt...-Assist/page2&
Luck Favours The Prepared
Anticanman is offline
post #6 of 20 Old 04-27-2013, 03:57 PM Thread Starter
JeepRocks86
Durango box a direct replacement ?
For Sale:
post #7 of 20 Old 04-27-2013, 03:58 PM
PA_YJ19
Hmm never saw or heard of that before, doesn't look to difficult but looks like a lot of mess for not much result. I like the idea of boring out my stock one but I'm not sure I'd feel real confident on the street after all of that. There has to b a v8 Chevy out there with a bigger pump and similar mounting location. I think I could rig one to the stock bracket as long as it isn't majorly bigger than the stock one. I'll make a trip to the JY this week and start looking, I would tmrrw but I have to work in the morning.
PA_YJ19 is offline
post #8 of 20 Old 04-27-2013, 03:59 PM
PA_YJ19
Yes it is, it uses one less bolt on the frame tho. I use a steering brace I built similar to the MORE one, I had no issues with it moving before I built the brace tho.
PA_YJ19 is offline
post #9 of 20 Old 04-27-2013, 05:03 PM
USMCBuckWild
I found several of the Chevy and Ford P/S pumps that are high output, typically used on large vehicles. I had to locate one in prep for my Hydroboost swap. Pirate has a couple of write-ups on what vehicles to look for those pumps in.
http://www.pirate4x4.com/forum/chevy...pump-info.html
I lucked out and got one from the junkyard that is in perfect working condition. The pump itself should be able to be mounted into the pump housing.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #10 of 20 Old 04-27-2013, 05:14 PM Thread Starter
JeepRocks86
Well the YJ I'm looking at has a Chevy v8 out of a k5 blazer I believe so maybe it has the better pump.
For Sale:
post #11 of 20 Old 04-27-2013, 05:26 PM
USMCBuckWild
More than likely it doesn't. You need to physically remove the pump from the housing and look at the back of it to clarify if it is a HO pump or not. It took quite a bit of searching to score one. Check the parts stores, I found one at the parts store as well, but wasn't spending that much and returned it.
post #12 of 20 Old 04-27-2013, 08:09 PM
TSEJEEPERS
I am using the Durango box.
Yes it is a direct replacement.
Yes you only use 3 of the bolts.
Yes it turns my tires great offroad.
Yes I did loose some turning radius.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #13 of 20 Old 04-28-2013, 08:11 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Though a bolt in, use all 4 bolts that hold on the original Jeep frame adapter bracket, not just the three that hold the gearbox on. This adds a lot of strength, keeps the mount from stressing the frame metal.
Yes you loose turning radius, those that say they have not just have not noticed, or they already had the turning adjuster bolts adjusted lower for wheels or something. You can swap in a pitman from a Grand Chero, which is 3/4" longer hole to hole. You have to cut a couple splines in the new pitman though, I used a hacksaw, so it slips onto the Durango shaft in the proper orientation. I concur that a brace to the other side is a good idea, especially with the differences in the frame mount.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #14 of 20 Old 06-03-2013, 08:52 AM Thread Starter
JeepRocks86
Ended up getting another YJ. 95 fuel injected 302 8.8 arbs 35s etc. went wheeling and Got it back on the trailer and had a nice few drops on the trailer deck from the seal leaking. I guess it's one for an upgrade.
For Sale:
post #15 of 20 Old 06-03-2013, 10:04 AM
Louie4
What's the overall distance from hole to hole?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
