YJ Stalls then won't start for a while - JeepForum.com
post #1 of 10 Old 01-07-2014, 09:33 PM Thread Starter
johntmcnally
Occasionally I have dropped the clutch too quickly on my '92 5 speed yj. the car stalls, but will refuse to start after that, as though the stalling temporarily killed the engine and starter. I have to wait 20-30 minutes, and it will start up just fine. runs great after that like nothing happens. How can I bypass this starter kill so I can start up right after a stall?
johntmcnally is offline
post #2 of 10 Old 01-07-2014, 09:36 PM
Billy
http://www.jeepforum.com/forum/f12/9...awhile-975737/
http://www.jeepforum.com/forum/f12/8...start-1086704/
That should get you started...
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #3 of 10 Old 01-07-2014, 09:38 PM
Billy
My gut reaction says fuel pump, but check for codes and get back to us.
Billy is offline
post #4 of 10 Old 01-07-2014, 09:40 PM
Billy
I also think your jeep might be just too cold up there in Detroit. As if its saying "**** that! I'm not going out in this weather!"
Billy is offline
post #5 of 10 Old 01-08-2014, 07:30 AM
Que89YJ
Check your codes like Billy suggested and post what you get. This shows you how:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #6 of 10 Old 01-10-2014, 12:11 PM Thread Starter
johntmcnally
Thanks a lot guys. I checked the codes, got the normal 12 33 55. I will look further into the fuel pump.
post #7 of 10 Old 01-10-2014, 05:14 PM
Que89YJ
The next time it stalls and doesn't want to start, disconnect the battery for 10 second and then try and start it. It will reset the ecu and force it into open loop. It will tell you if it's sensor related.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 10 Old 02-08-2014, 07:41 AM Thread Starter
johntmcnally
Did it again a few days ago, tried disconnecting the battery for 10 secs and still wouldn't start.
post #9 of 10 Old 02-08-2014, 07:54 AM
Que89YJ
Ok. So open/closed loop doesn't matter. You need to do a couple things. Check your fuel pressure. Could be it's flooding. Also you need a meter. Under$20 @ harbor freight or radio shack. Go you know how to use a meter to read voltages?
Fault codes:
No Start:
Que89YJ is offline
post #10 of 10 Old 04-18-2014, 09:58 AM Thread Starter
johntmcnally
Swapped the gas tank last week, including the fuel pump, problem solved! Thanks for the help guys
engine , stalling , starter , YJ
